Old 05-08-2012, 11:19 PM   #1
bchrny
Default will a HP-EOS720DUO HYPERION charge an a123 pack???
I have this charger on the way to me. HP-EOS720DUO HYPERION 0720I DUO 3 500W+500W 20A 2 X 7S 1000W 14S MAX Will It charge A 123 baterries? I have some A123 batteries in my plane ( Extrem flight 50cc) and its got two A 123 batteries hooked up to a charge port switch which I will want to hook up to and charge through. Is this possible?
E-Flite Blade mCX x2, E-Flite Blade CP PRO, Align T-Rex 450 SE V2 w/ Hi-Tec HS 65HB cyclic servos, JR DS 3500G tail servo, E-Flite RG 90HL gyro, Align RCE-BL35X esc, Align 430X 3550 KV brushless, Spektrum DX6i DSM2 TX, Spektrum AR6200 RX
bchrny is offline        Reply With Quote
Old 05-08-2012, 11:26 PM   #2
jaccojenkins72
hey I just posted that thread????? whats up with that? jaccojenkins72
jaccojenkins72 is offline        Reply With Quote
Old 05-08-2012, 11:37 PM   #3
superjoe83
yes, it will, you have to use the LiFe mode, but it will work just fine
T-Rex 450PRO V2, T-Rex 700E V2, T-Rex 500EFL Pro ICE100 Vertigo motor T-Rex 550 FBL BeastX, KDE/Neu, ICE100
superjoe83 is offline        Reply With Quote
Old 05-08-2012, 11:45 PM   #4
bchrny
Default Post to new thread so everybody knows your post jaccojenkins72
Post it to a new thread so everyone sees your thread. Not on another post, noone will see it!
Old 05-09-2012, 07:34 AM   #5
mtuccio
Yes this charge will work with A123. You will need to charge using LiFe mode. This is a very nice charger and I run one of these in my shop. Just make sure you get a really good power supply to deal with the 1000W power demand from the setup (You will need about 1200W to use its full potential).
Hope this helps....
mtuccio is offline        Reply With Quote
