Old 05-08-2012, 11:08 PM   #1
mammothtarm
Default Bearings Ever need Lube?
Are you suppose to Lube your bearings? If so, how often and when?
mammothtarm is offline        Reply With Quote
Old 05-08-2012, 11:11 PM   #2
Liduno
I put a little 3and1 oil on mine every 20 or so flights, a drop on the motor shafts too.
B400 130X MCPX MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED.
Liduno is offline        Reply With Quote
Old 05-08-2012, 11:14 PM   #3
mammothtarm
ok... thanks. don't need to lube my C05 right?
Old 05-08-2012, 11:15 PM   #4
Liduno
The bearings
Old 05-08-2012, 11:18 PM   #5
mammothtarm
10-4. thanks.
Old 05-08-2012, 11:34 PM   #6
Talesin
Some do. Some don't. There's a good 'mCPX Maintenance' thread on one of the later pages of the mCPX forum regarding lubing the chassis bearings. I haven't and have not had a problem so far.
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X
Spektrum DX8, DX6i
Talesin is offline        Reply With Quote
Old 05-09-2012, 12:13 AM   #7
Imzzaudae
Default Hi
Some links about MCPX.
Dealing with tail wag / See servicing your MCPX link.
http://www.helifreak.com/showthread.php?t=407020
Hope this helps you.
Ron
Ron Petrolia Ontario
CX2,MCX2,MSR,120SR,Rescue Heli,MCPX,MCPX-bl, B450 DX6i Now building a Hirobo shuttle 30 size
Imzzaudae is offline        Reply With Quote
Old 05-09-2012, 03:40 AM   #8
Tasteles
Here's liftbag's post on oiling the brushless motor, I think the one in his pic is an HP05 but the C05 should be the same.
http://www.helifreak.com/showpost.ph...8&postcount=17
Tasteles is online now        Reply With Quote
Old 05-09-2012, 06:00 AM   #9
youturnjason
I've never oiled mine and haven't had any problems so far. Even with my 450 I found once I started oiling bearings I had to keep oiling them every few flights. Now I don't oil them at all.
youturnjason is online now        Reply With Quote
Old 05-09-2012, 08:12 AM   #10
temtnf8
Bearings are packed with grease from the factory. Adding any lubricant to them that is thinner than the grease thins the grease, resulting in more frequent lubrication being required.
temtnf8 is offline        Reply With Quote
Old 05-09-2012, 08:16 AM   #11
Cgarr
I grease mine about every 70 or so flights. You can see all the gunk being pushed out and the good stuff going in.
Cgarr is offline        Reply With Quote
Old 05-09-2012, 08:27 AM   #12
Sambuka
250+ flights no oil on bearings, 150+ crashes still flys perfect
Sambuka is offline        Reply With Quote
Old 05-09-2012, 08:50 AM   #13
Killgore Trout
I've found the same thing. I used 3 in 1 oil a few times at the start, but had to frequently oil them after that as it felt like the bearings were picking up extra dirt (or just drying out earlier).
I now use spray white lithium grease on frame bearings and my swashplate bearings. Everything feels MUCH smoother now that I've switched over to white lithium and I don't have to clean them out that often. I fly in a sandy environment, so my bearings get nasty quickly. The spray can white lithium is nice to be able to forceably clean out the bearings.
Killgore Trout - MCPX v2, MSR, Dx6i
Killgore Trout is offline        Reply With Quote
Old 05-09-2012, 09:50 AM   #14
temtnf8
Another option - replace the bearings with sealed bearings. These are .5mm thicker, but with a slight adjustment to the servo link lengths (or custom-made main shafts) they would work just fine.
http://www.vxb.com/page/bearings/PROD/3mm/Kit7033
