Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 05-09-2012, 04:55 AM   #1
donskills
Default Update and questions!!
Greetings fellow TDR freaks!! weekend gone I passed the 100 flights mark with my TDR and have Flown the machine for exactly 10:02:06 hours!! I have gone thru two tail fins and tail blades due to clumsy autos. Apart from that the heli is like new!! I am still as "over the moon" about it as I was after the first few packs, I completely love it!! I have on the other hand started to increase the pressure on the machine, flying wise and have noticed the the Pyro is landing quite a bit warmer now (60-70 Celsius). I checked my VBar log yesterday and although nothing serious, I have two spikes at around 18k and 21k rpm. I am guessing that the bearings in the pyro are maybe starting to complain, any thoughts? I have not checked the bearings in the tail blade holders after the bad autos but have not had any visible problems after them so haven't bothered but I will soon as a little more involved all round service is due. I grease the gears and do smaller checks all the time any how. I have ordered some 6x15x5 and 6x13x5 ceramic bearings for the Pyro in case a change is due right away.
The best of weather to you all!!
Henseleit TDR 2011, Spirit, BLS451/251,Pyro30-12, Kontronik Kosmik 200+Jlog2.6GW, Radix 710FBL, Radix 110 tails.
AccuRC, realflight 7, Jeti DS-16.
donskills is online now        Reply With Quote
Old 05-10-2012, 04:26 PM   #2
dswitkin
20K RPM definitely sounds like the motor, the tail would be more around 10K for 2K on the head. I would change the motor bearings. Just be careful to not crush the windings when you do it. This video for Scorpion motors may be helpful:
http://www.youtube.com/watch?feature...&v=3RJQfbzXNjQ
dswitkin is offline        Reply With Quote
Old 05-11-2012, 04:25 PM   #3
rctintin
Hi mate, not a good idea using the ceramic bearings, as they are not designed for side loads. They are designed for radial loads only, hence why they are used for turbines.
I remember reading about the pressure put on our pinions, especially when using slanted gears. I think it was a test done by KDE when they were developing their electric conversion of the T-Rex 700N, and they found the side load pressure was very high (can't remember the figure, but hundreds of pounds)
TDRx2, Synergy N7/E7se/N5cTT, Align 450L/550/700e/700n, Gaui NX7/NX4, , Goblin 700/Black Nitro, Futaba 18MZ/ V-Control All on V-Bar's and S-Bus. #0095
rctintin is offline        Reply With Quote
Old 05-11-2012, 07:37 PM   #4
marcosp
On a 700 sized heli, with regular straight gear, with standard motors such as 4035 at full power it's about the weight of an adult male standing on the shaft. I remember that because it was a very clear image!!!
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote
Old 05-12-2012, 05:32 AM   #5
donskills
Greets Guys and thanks for your input!! I checked the motor bearings and they are fine so I left them in place. I also checked the tail blade holder bearings and they are as new!! I suspect my gear mesh has been a tad too tight due to rising ambient temps so I have backed it off a hair and will see! I must also admit that I have been of late pushing the heli a bit harder than ever before which is probably the main cause of the rising motor temps! I can keep my fingers on the pyro after a flight albeit quite warm but I cant hold my fingers on my buddy's 700MX for more than 10-15 secs so I am ok I think. I guess i will save the ceramic bearings for something else!! I thought I read somewhere about such bearings in a pyro but I am probably misstaken or mixing up facts!!
Old 05-12-2012, 09:17 AM   #6
Spinny02
Hey Don,
The Pyro Black Edition has Ceramics in her.
JS
Spinny02 is offline        Reply With Quote
Old 05-12-2012, 09:23 AM   #7
mkovalcson
Originally Posted by Spinny02 View Post
Hey Don,
JS
I thought they were ceramic coated steel no full ceramic.
Mark
2011' Protos 500, 2014' Logo 550SX, 2012' TDR, 2015' Protos Max V2, 2016' TDR2
2013' Jeti DS-16
mkovalcson is online now        Reply With Quote
Old 05-12-2012, 09:36 AM   #8
ZuvieleTeile
From what I heard they are hybrids.
Ceramic balls and steel races. But that might be a rumor too.
Kind Regards ZT - TDR,
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote
Old 05-12-2012, 10:02 AM   #9
donskills
The bearings I bought are actually Ceramic hybrids with ceramic balls and steel cages!
http://www.kontronik.com/index.php?o...tid=80&lang=en
Old 05-12-2012, 04:48 PM   #10
Mercuriell
I used ceramics in my Pyro for about 50 flights with no probs, KT took them out when I sent the motor back for crash damage service
John
Mercuriell is offline        Reply With Quote
