| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Anyone know if this flybar head will fit the 600 nitro?
I don't know what you call the v2 but the 600EFLpro head will fit on the 600N.
Check out my post on some minor modifications that I would recommend. http://www.helifreak.com/showpost.ph...3&postcount=21
Trex 600EFLpro
Trex 600NSP DFC Goblin 700 |
#3 |
Never mind - I thought you meant FBL...! My bad ! DOH !
Trex 600EFLpro
#4 |
yes it will fit. The v2 head has shorter pins than the older v1 allowing the washout assembly to fall off without power to the servos. No big deal, you simply make sure that your assembly is on the pins when you power up.
Also, the v2 uses a sleeve in addition to the dampers where v1 has dampers only. I don't think the sleeve is a requirement, just tightens things up a bit. I don't know if the geometry is the same so it's possible that you may have to adjust linkages as necessary
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910 |
#5 |
+1, dont know why I dident get in here sooner. I have this setup on mine, I used a pair of vice grips on the pins and carefully twisted and pulled the pins out to match the mm count of the plastic head. Did not want to stall my ds610's and let out the smoke.
Just had my first baby, Chloe 8-oct-2011 so with my heli's i dont get to play: Trex 600N, Blade 400, PKZ P-51, PKZ Radian Pro. |
