| mCP X Blade Micro CPx Helicopters Information and Help |
flying with my father other morning we was comparing each others mcpx's and notice that the links from the main blade grips to the swash they is play back and forth on the balls. quite a bit for such a small heli i never had noticed before
is there play on a brand new one? os is the swash balls wearing? my swash was only about 5 flights old at that time. or just the plastic ball links wearing out? are they all driffrent size and some tighter then others or what is this why some go aluminum n swash do they take out the play? my links are getting a bow in them to the outside i was thinking about taking some fishing line and tieing around the two to pull them back in to the center. i guess should just replace them but running low on them thanks for info this is not a new heli to me but i seem to notice more and more about it all the time ...
,B450 w.HS65MG,ZYX Tarrot Head FBL, Billowy Batterys ,MCPX BLack dragon oversky 10a, Blade CP pro BL |
Yep. That's what the canopy grommet mod fixes, when you put the spare grommets over the balls, so they push the links outward and take up that slop. Works on the servo->swash links, and the blade grip balls too. Can get smaller ones for the bottom part of the pitch links too.
Blade: mCX2, mSR, mSRX, Nano-CPX, 2x mCPX (v1), mCPX-BL, 120SR, 450 X Spektrum DX8, DX6i |
#3 |
Yes, the links are not of high quality from HH anymore and I couldn't even get them to checkout the problems. Early links were great fit and the latest links are junk. I've got a bag of 25 or so that are looser that goose poop! HH has either messed up the molds or their process is out of control. There are after market links from AEO but I haven't tried them yet. According to Dylan of Asteriod Designs they fit really nice.
YMMV, Don |
#4 |
Yeah my new links are super loose they go on easy and are loose on the swash and pop off to easy compares to the original ones
#5 |
I use these as quite a few other members here do also.
Silicone "O"rings - http://www.helifreak.com/showthread.php?t=367386 |
#6 |
I also have noticed that the new links are sloppy and used the canopy grommets to take up the slack.
Blade 450 3D w/beastx tarot fbl, 450x, mQX, mCPX V2 xtreme on DX8 Align TRex 500EFL Pro ar7200bx, tm1000 and sat Walkera v200d03, v120d02s on Devo 8s Realflight 6, AMA 986509 |
#7 |
left over dampeners from feathering shaft kits work well on the blade grip balls
Current: 130x, CopterX 450 Pro FBL*Build in Progress* Gone With the Wind: MCPx, E-razor 450, Nine Eagle Bravo SX |
#8 |
Thanks guys at least i know now that not all of them are like that pretty sure my 1st one wasn't so loose.
the feathershaft dampers seem like they would be to big but i will check them out. I use the msr canopy grommlets on the metal links to the swash from the servos
#9 |
The AEO links are fantastic. They do break easier though.
#10 |
thanks for the heads up about breaking. seen there $2 for 8 might have to try some
