| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
#41 | |
Rick
Helifreak, the place to be! Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X My products, flown by top pilots around the world, like you! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#42 |
So, any word from MrMel ?
#43 |
#44 |
Not yet. The suspense is killing me ...
#45 | |
Check sum is a math trick used to verify the data from the sensor is not corrupted. this is standard practice with good electronics. when you see "check sum error" it means that the controller looked at the sensor data and decided it was corrupted. and it will discard that data and wait for good data. if a few packets of data discarded, its no big deal. but if all the data is discarded, then the controller is flying blind. I had the same issues with my logo 600.
Greg Lynx Team Pilot Heli: TDR; Logo 600,500; Trex700E,500,450,250 Flight video: http://www.youtube.com/watch?v=GUkswcoyGEk&feature=plcp Last edited by el guapo; 05-10-2012 at 01:24 PM.. |
#46 |
+1 to static being the issue. I had a few data checksum errors on my 600se this winter. After grounding, the tail kicks and error messages disappeared. However I would wait for word from the Vbar Yoda ( Mr. Mel) before closing the case.
Logo 600se |
#47 |
Yah MrMel would be able to tell you if the unit needs servicing or not.
Logo 500 VBAR GOV/YGE MSH mini-p VBAR mcpX V2 mikeaarset.zxq.net |
#48 |
The Capi - HF Support
Rick tell me when it's not too early to kick you when you are down.
SAB Heli Canada / RotorQuest/Compass Team KBDD Spreading capibara awareness since 2006 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#49 | |
I am familiar with checksums. I assumed that error would be kind of a catchall for anything that corrupted the data stream. I just wasn't sure what all would produce them. For instance, if a sensor was faulty, had a bad connection, or the internal sensors had come loose from their mounting, could that corrupt data as well? Also, I assume some errors cause other errors and can therefore make the logs a bit misleading if you don't fully understand what they are telling you. I didn't really expect static buildup to produce such continuous errors. I would have expected periodic bursts of errors around when a discharge occurred (tail kick or shutter), or a reset for instance. I'm impressed with the logging that is done. Is there documentation on line somewhere that further decodes the info in the logs and give examples? Rick
#50 | |
But feel free to give a kick, just in case, rodent... hehe Rick
Helifreak, the place to be! Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X My products, flown by top pilots around the world, like you! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by rdlohr; 05-10-2012 at 04:59 PM.. |
#51 |
I am thinking about the "Sensor Connection broken" error. It should not happen even in a static discharge situation. Why don't you try to power up the V-Bar unit on the bench and try to shake the sensor by hand. If it is a bad wiring it should be noted in the log.
I am not aware of any detailed explanation of the log entries except those in the PDF file. |
#52 |
Yep. You are thinking like I am. I'm going to hold off until I hear from Mr. Mel for a little, but then I plan to try exactly what you said. I'll also try some vibration, pulling out antenna wires, sensors wires and whatever I can to get a good handle on how this logging stuff works.
#53 | |
if you have a heart attack, a symptom is your left arm goes numb.... obviously if you sit on your hand it can go numb without the heat attack. but, if you vbar has check sum error its probably static. it the canary in a coal mine...if you use the search feature, you see two common issues. 1 motor bolts shorting the coil of the motor and 2 static. its always some form of electrical glitch. its dry and its winter. prime conditions for static.. anyway... below is a link to my thread... with my log... . you'll see the same errors in my logs.. my heli tried pretty hard to kill it self. but I saved it. I added the ground wire and removed the aluminum pulleys, then it was fixed. it is easy for me to accept the correlation of the failure mode at face value, although I was skeptical until it was fixed.. you planted your heli, so its hard to test. http://helifreak.com/showthread.php?t=369934
Greg Lynx Team Pilot Heli: TDR; Logo 600,500; Trex700E,500,450,250 Flight video: http://www.youtube.com/watch?v=GUkswcoyGEk&feature=plcp |
#54 | |
Rick
#55 |
V-BAR Guru
It's a tell-tell sign in the log how static looks like.
Sorry about the crash but Logo 400 needs grounding. Even though in theory the black belt should not need it, it does, mine does not fly well a single flight without grounding, I broke it inflight and the result could have been the same as above but I saved it.
Gone fishing.. or hunting or something.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#56 | |
Is there anything on line which explains log files? Edit: I just saw your note regarding PMs in your sig. I had no idea. What is the best way to contact you?
#57 |
Best way to get hold of Mr Mel is just to post your log in the Logo or vbar forum.
He is like the all seeing eye of Sauron, nothing escapes his gaze |
#58 | |
V-BAR Guru
So ground the boom I have turned off PM but you as hf support can override
#59 | |
Rick
#60 |
Only quitters gonna quit Rick;-)
Team Thunder Tiger Europe 4RC.nl, Edge rotorblades, Scorpion systems To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
