Old 05-12-2012, 01:00 AM   #1
TBur
Default Power options for the power bus
Just goit a 720/w power bus for my new 12S 6hv build. I'll be running the servos @ 6V. I was hoping everything could be run off the BEC at 6V. Is that possible ?
720 docs say 5 - 10V, power bus says 7.2 ?
Only got the power bus for conveniece at this point, and the possibilty of changing to HV servos later.
Tim
7HV NEO 700XF
Goblin 630 NEO 600XF
Agile 5.5 NEO
Vcontrol
TBur is offline        Reply With Quote
Old 05-12-2012, 02:04 AM   #2
Groucho_
If it runs without the powerbus at 6 volts, then it will run with the powerbus at 6 volts. You have nothing to worry about...
Groucho_ is online now        Reply With Quote
Old 05-12-2012, 09:49 AM   #3
TBur
Groucho - thanks - thought I'd check before powering it up
7HV NEO 700XF
Agile 5.5 NEO
Vcontrol
Old 05-12-2012, 11:05 AM   #4
taoY
I run power bus directly to 2S lipo and another one to a BEC at 8.2V. No problem.
TDR II, 2xTDR, Logo 700 XXtreme, Logo 550SX V2, Trioblin 700Comp w/KDE upgrades. KDE motors on all helis
taoY is offline        Reply With Quote
