Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-28-2010, 05:13 AM   #21
wouterd
Originally Posted by beenflying View Post
No. It should be 26.9 from the front and 31.8 from the tail, which is 3cm forward from the center.
In the manual in my recent 550E (fb) box (purchased 22/12), these updated numbers for the torque tube settings are already in the main text (no correction page(s) added neither).
My manual now also shows an extra plastic tube (which is included in the box) to more easily insert the torque tube in the tail boom by pushing directly onto that bearing holder (so it will not move or twist while pushing in the torque tube). Good idea!
BTW: Do the Align manuals have version numbers? Where do I find them?
wouterd is offline        Reply With Quote
Old 04-28-2011, 09:09 AM   #22
DILLIGAFF
That is interesting because the manual I have says "about" 25.9 and 31.8.
Anyone have a feeling for which number is correct?
DILLIGAFF is online now        Reply With Quote
Old 05-24-2011, 04:09 PM   #23
whittb
Default re
Good, it means my existing spare 600 landing gear spares will work. I checked the 550 instruction Manuel and sure enough, they match.
It makes finding parts that much easier.
thanks
whittb is offline        Reply With Quote
Old 10-03-2011, 05:48 AM   #24
tommy158
i put 2 TT bearings in my 550.. i just split the difference for spacing... flys great with no wag in tail from the beginning....zero vibration
tommy158 is offline        Reply With Quote
Old 10-07-2011, 12:46 PM   #25
avengedkevinfold
where can i find a manual for the 550 3gx?
avengedkevinfold is offline        Reply With Quote
Old 10-11-2011, 01:25 AM   #26
heli1236
http://www.align.com.tw/alignhtml/EN/index.html
Then select Downloads, Then Manuals, Then Remote Control.
Then scroll down to find the manual you want.
Tarot 450PRO, ZYXS w sat
Trex 500ESP, AR6200, 3G/9254, CC Ice100, CC Vertigo 3424-1760KV motor,
Trex 550, AR7200, CC Ice 100, 112/11 Helical gear, Gens Ace 5300 's, Align 550mm blades
heli1236 is offline        Reply With Quote
Old 10-20-2011, 06:08 AM   #27
jonp
Just recieved my new 550E V2 and looking through the manual have found a mistake as follows:
The manual is dated August 2011.
Page 19 - The illustration of the tail gear box and tail rotor shows the tail blades mounted backwards.
T-Rex 550E V2 / DS-610 / GY401 / 620 / CC ICE 100
T-Rex 600 ESP / DS-610 / GY401 / 9254 / CC ICE 100
T-Rex 700E F3C / DS-610 / GY520 / 650 /CC ICE 2 HV 120
jonp is offline        Reply With Quote
Old 10-21-2011, 01:03 PM   #28
Bosman
Originally Posted by philipfrank View Post
if you follow the manual it is about as easy as it gets.
it shows you step by step.
My first ever build and I found the whole manual required a thorough study before starting the build. All mechanics in manual is 100%, but lacks a lot of information on the electrics/electronics - specially for a first timer like me.
Bosman is offline        Reply With Quote
Old 01-26-2012, 12:07 AM   #29
beenflying
Link to the 550E V2 manual:
http://ms.align.com.tw/mpeg/manuals/...s/kx021007.pdf
Link to the 550E 3GX V2 manual:
http://ms.align.com.tw/mpeg/manuals/...s/kx021008.pdf
Gaui X2 FES ZYX, Gaui 425 FB, Gaui X5 FES MB v3,
250 DFC ZYX, 450 V2 FB, 450 DFC Sport ZYX,
ALZRC 450 Pro FBL 3GY v2, Devil 450 FAST VCTRC 3GX, 500 DFC Pro GV8000 VBar, O6
500ESP SDC ZYX-S
, 700E DFC HV iKon, O7, 550E DHPS FBL HB800, O9 - ZYX v4
beenflying is offline        Reply With Quote
Old 01-26-2012, 05:23 AM   #30
1004ron
That is for the early V2's
Would like an electronic copy of the late V2 with helical main gear and 600pro head.
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / T-Rex 450 Sport - 3GX - Tarot head / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is online now        Reply With Quote
Old 05-04-2012, 02:03 PM   #31
HK
Thank you. The align site has closed the heli manual sector.
HK is offline        Reply With Quote
Old 05-05-2012, 11:38 PM   #32
johnahamelv
The lack of readily available manuals to accompany the frequent changes and "upgrades" in parts is one of the reasons why looked outside Align for a 700 size heli. It is just too frustrating and time-consuming when I need to purchase new parts, and Align keeps it unclear what parts are compatible with whatever parts I have. Too often I purchase replacement parts, only to find the new parts or versions incompatible with my current parts. If manuals and revisions where available online, I would be be able to find the parts I need rather than just making a best guess. Considering the limited company support and lack of available manuals, I do not think I can purchase another Align helicopter to add to my fleet.
Whiplash E--ICE2HV160/KDE-495/MKS HV's, Synergy E5/S--ICE2HV120/KDE-530/Futaba HV's
T-Rex 600Pro XT--ICE2HV120/KDE-530, T-Rex 550--ICE100/KDE-1175, B130X, mCPx
VBar Silverline x4, Lots of KDE, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is offline        Reply With Quote
Old 05-06-2012, 12:10 AM   #33
Wolfpackin
Very well said Sir.
But I would likely buy another Align heli if I were in the market simply because they offer a decent product within my budget with readily available parts support.
Although I agree, determining which part to buy can be frustrating to say the least.
I would just ask Align to reconsider this decision, and if anything, make online manuals and part information MORE available.
Come on Align, give us a little help here!
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 05-10-2012, 09:46 PM   #34
Hoosiermo1
Here is the new 2.1 manual.
http://dl.dropbox.com/u/65359970/550...DEC%20ver..PDF
Hoosiermo1 is offline        Reply With Quote
Old 05-10-2012, 11:13 PM   #35
johnahamelv
How do you ask Align to reconsider? They do not respond to my messages sent to their main website in Taiwan, and the folks at AlignRC, cannot give me a good explanation why Align will not post those manuals online.
Interestingly Align is not the only company that makes you jump through hoops to obtain a manual. Synergy's Matt Botos responded on the Synergy forum the he has not posted the Synergy E6/E7 manual because of concerns that [unscrupulous] manufacturers may copy his design. Compass also does not have the manuals on its website.
When choosing the 700 size heli, I excluded the companies that did not have readily available manuals online, especial manuals with actual part numbers. Interestingly, I found that except for Align, Synergy, and Compass, all other companies/models I researched (Mikado Logo 800 XXtreme, Henseleit TDR, Next-D Rave Ballistic, SAB Goblin 700, Thunder Tiger Raptor G4 E720, Gaui X7, MA Whiplash, minicopter Diabolo) had the manuals easily and readily accessible on their respective websites. With the Synergy E6/E7 and Compass 7HV, there are non-scanned excellent quality PDF versions of the manuals available, but you have to ask around in forums to find these. These two helicopter manuals are not easily and/or readily available. With Align, you are dependent on the help of Good Samaritans to obtain lower quality high MB scanned PDF versions of the manuals (Not cool).
Old 05-13-2012, 02:25 AM   #36
Vinno
http://vinno.net/manuals/Trex550V2-K...-2012APR19.pdf
Scanned all pages from start to the 3gx setup bit and scan last back page also.
Ef-flite MQX - Blade 120 SR - Blade MCPX #1 - Blade MCPX #2 Brushless
Align 450 Pro V2 Spektrum Beastx FBL #1 | Align 450 Pro V2 Spektrum Beastx FBL #2 | Align 550 Pro V2 Spektrum Beastx FBL
Vinno is offline        Reply With Quote
Old 11-22-2012, 10:25 AM   #37
peerinto
Originally Posted by cdkoho View Post
hey bob are you going to do a video on the 550 flybarless version align heli.i know you are busy but this would be a great build for beginners entering flybarless.
thanks mike
Yes, Yes i would love to be able to see (follow) you as it's being put it together. When i did that with my 500 build, flying it has been enjoyable.
peerinto is offline        Reply With Quote
Old 12-13-2012, 05:55 AM   #38
__sin__
Please somebody add the manual for new T-Rex 550E DFC. Thanks
T-REX 550 DFC + 3GX 2.1 + ICE 100 + CC Bec Pro + MKS BLS-980
T-REX 450 Pro 3GX v2
SPEKTRUM DX7
__sin__ is offline        Reply With Quote
Old 12-14-2012, 12:17 AM   #39
gixster
Default Align 550 DFC V3 Manual.pdf
Here you go, just scanned it in
Trex 550e DFC (V Bar,Scorpion HKIII 4025-1100, Rail 556 / 96, CC Edge 100)
Trex 450 DFC (MSH Brain, Scorpion 2221-8, Rail 326's, CC Edge lite 50)
Futaba 14SG, DX6I, Phoenix 4.0 , Real flight 6
gixster is online now        Reply With Quote
Old 12-14-2012, 08:44 AM   #40
__sin__
Good job. Thank you. Respect!
SPEKTRUM DX7
