| MA Gas Miniature Aircraft Gas Helicopter Support Forum |
I have developed an amount of sideways play in my Spectra G Tail Gear box output shaft.
Any idea if there is a list of replacement parts available to 'refurb' this? I can't find any reference to spare parts that may be available. Any idea of what may be required?
---- Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N YS120 Vbar v5.3 ----- T Rex 600N YS60SR Vbar v5.3 ----- MA Spectra `G`----- T Rex 500 Gyrobot 700 ---------- Vario Sonic ---- |
Pretty well all that can cause sideways float is the grubscrews in the output shaft gear being loose enough to let the gear slide on the shaft; that'd give you lots of backlash between the gears in the tail box......
Peter To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Furion 6 FBL ; E,N and G Whiplash FBL ; 3 Spectra G FBL ;3 Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: Aeolus KME 60 , 2 Velocity 50's FBL; few 500's.. All BeastX ; guided by XPS . |
#3 |
Would be a new tail case. I attribute that to some wear and tear where the bearings would fit in the case either from crash damage (bent tail rotor shafts) or just usage over the years.
-=>Raja.
1005 Xcell Autorotation Queen, Hanson G26 3D Max, 3334 flights Spectra-g, Hanson 270 3D Max, 2202 flights Whiplash-g 88.9mph Speed Cup Record, Hanson 270 3D Max, 280 flights Jewel on-board Generators, Team Miniature Aircraft, Team Helicommand |
