Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 05-24-2012, 10:38 PM   #1
nwmartin
Default SAB BLADES???????????
Can someone tell me what SAB blade are FB & FBL how can you tell I have 90 nitro
nwmartin is offline        Reply With Quote
Old 05-25-2012, 05:57 AM   #2
nwmartin
Default SAB Blade
I gess no one know or ---- thanks for your help EDGE Blade it is
Old 05-25-2012, 07:00 AM   #3
gww528
Good choice... Edge are on the Goblin
gww528 is offline        Reply With Quote
Old 05-25-2012, 09:02 AM   #4
deepak
When you purchase a set of Sab's it written on the box. Sabs over the last few years have been fbl ready. If you got a goblin its fbl ready! On your nitro, perhaps you should post a pic
and let us see what your flying, Is the blade new?
Sabs in my opinion are better that the edge. Less noisy and lighter
They're big in Europe.
regards
D
deepak kirpalani
Deepak.g.kirpalani@gmail.com
deepak is offline        Reply With Quote
Old 05-25-2012, 10:04 AM   #5
Thunder Fighter
The SAB's aren't really coded in the same way others are. It doesn't apply to all of the blades but normally the plain white and black are the heavier blades suited more toward stability and FBL, the Red/Whilte/Black blades are lighter and more agile so good for 3D type flight both Flybar and FBL.
//Dennis.
SOXOS DB7 : SOXOS 550 : SOXOS F3C : Protos Max V2 stretch 800 : Protos 380
SAB Goblin 700 nightflyer : Jeti DS-16 : Mini Protos FBL Stretch : Logo 600
www.soxosaustralia.com.au
Thunder Fighter is offline        Reply With Quote
Old 05-25-2012, 07:38 PM   #6
Blink 182
Cool, what size are you getting?
(・ω・`) ギルティクラウン
Blink 182 is offline        Reply With Quote
Old 05-26-2012, 06:28 PM   #7
nwmartin
Default BLADES
THANKs for replys 700mm or 710 my friend got me a Radix blade to try but later will try the black & white THANKS ALL FOR THE INFO
