| 600 Class Nitro Helicopters 600 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Hey guys,
I'm new to the nitro game, and have been flying electrics for some time. I recently built my first Trex 600 nitro pro, and was wondering what you guys recommend for starting these things. I will be using an 18v cordless drill, what shaft should I be using to start it? http://www.gforceheli.com/item/ProStart are these worth it? Are there good/bad glow plug igniters out there? What hand refueling pumps are good and which ones should I stay away from? Thanks for your help, and if I missed anything please let me know. |
I use the Align starter, which I got used from a buddy for $50, including a lipo battery. Glow ignition is via the align 2 in 1 that comes with the combo kit, although I've heard good things about switchglo, which lets you rig up the ignition to your transmitter via a spare Rx channel. I use a six shooter hand pump, which fills the tank in less than 30 sec.
My understanding is a drill works just fine for starting, as well.
T-Rex 550E FBL 3GX | Blade 450 3D T-Rex 600N Flybarred | OS .50SX Hyper DJI F450 Quad | Graupner props Futaba 8FG Super To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | Spektrum DX6i |
#3 |
6mm allen key as I recall maybe wrong
I would buy a flight box... holds battery and electric fuel pump and gallon of gas as well as has plug ins for glow starter and starter WELL WORTH IT
Raptor 50 w/upgrades; HK500 w/Align parts; BeltCPv2 w/ trex style head; Belt CPX w/Trex style head. Still learning... To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 |
I use a Husky open top tool bag I picked up at Home Depot for $20 for my field bag. Holds a gallon of fuel, pump, starter, a bunch of LiPos for my 450 and 600 Rx, lipo charger, all my tools, loctite, CA glue, Dubro balancer, charging leads, etc., pretty much everything I need to build/service my heli if I have the parts around. If I leave out the 450 flight packs, balancer, and charger, I can stick a second gallon in there, but I don't fly that much in a day!
#5 | |
Reunite the Parthenon Marbles "BRING THEM BACK" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 | |
Nitro Field Box- You can build this or buy one. I use a hobbyco field box but any tool box sufficient to hold your tools and fuel will work. In the box- Fuel- fuel pump (I use Hanger 9- http://www.hangar-9.com/Products/Def...?ProdID=HAN155), extra fuel tubing, clunk, inline filter, several glow plugs (these can go out any time, sometimes for no aparent reason), Long glow plug wrench, backup glow igniter (I use duo-bro http://www.rcplanet.com/Dubro_Kwik_S...r_p/dub666.htm) , alen wrenches, screw drivers, pliers, zip ties, knife (razor), locktite, volt meter. On on-board glow igniters, you can go with a regulator that has a built-in igniter (Align, Perfect Regulators, Scott Gray Gryphon) or something like the Switch Glow. I'm sure I've missed somethings but that's what comes to mind.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910 |
#7 |
Go to www.rchelination.com and listen to the last 2 recent nitro episodes.. There is a great ammount of info there and they touch on just about everything you would need and wanna know about nitro.. These guys rock !!
Pay attention to the part where they talk about the align 2 in 1.. Great idea but I dont trust it !! If u listen u will hear why !! Also I have noticed that my pushglow wont start the heli sometimes { mostly the 1st start of the day } and when I put my glow driver on it fires right up. I think its because the pushglow isnt getting enough juice to really get the glow plug hot .. Like I said as soons as I put the diver on it fires right up.. Getting a glow extension that allows you to start it from the side is a great option to.. Eitehr way having both is a plus.. Its also nice to start with a driver and then have the push glow on when walking away to help keep it running untill u spool it up... Dont know your fuel choice yet but I always reccomend Rotor Rage 20 percent of even the new masters blend 15 % .Its awesome fuel and I think alot of folks will agree !! I am now running the new 15 and it rocks !! Runs cooler and is cheaper .. Lots of pros are using it in the big motors and love it !! Good luck and make sure you check out the Nation because its great info ~!!! |
#8 |
For a starter, the Align starter has worked well for me.
The stock shaft wore out on me though, so I replaced it with the RJX shaft ($5) which has been holding up well. Get a high C rating pack, I have a 30C pack I use. Glow igniters: I prefer to run a SwitchGlo Pro. I HATED glow drivers. One more thing to charge, and always dead when I need them. The SwitchGlo is an on board igniter that uses receiver power to light your glow plug. If your RX pack is charged, you'll be able to light your plug! Additionally, you can program your transmitter in conjunction with it to prevent hot starts. I'll never own a nitro bird without one.
Team Miniature Aircraft USA Team HeliWholesaler, Team Byron Fuel's, Team Thunder Power, Team Scorpion -Darrick |
#9 |
Get the Align 2in1, powers your servo's and the glow plug
#10 |
the align 2n1 is less than 6v meaning your servos won't be performing at their best. Also, it's only 6A max. This is Ok for sport flybarred birds but if you're running flybarless and want to hit 3D, you may want to consider something with a bit more power.
#11 |
I have the Align starter. I catch grief from other nitro peeps about it jack hammering, but it starts the heli just fine.
I used to have a 2 in 1 but ditched it due to reliability concerns. I now run a straight Lifepo4 and all my servos are 6v rated. I installed a pushglo and that's what I use to light the plug
-Michael |
#12 |
what servos are you using? 6v and LiFe?
#13 |
Futaba 9452 cyclic
MKS DS 760 tail Hitec 6965 HB throttle Microbeast FBL
-Michael |
#14 | |
US Army VBAR PRO GOV MA Fury 55 Whip Nitro 105 Whip Nitro (2) FOR SALE |
#15 |
Hobbico starter with shaft extension, with a 4s lipo. Switch glow or push glow. You cant go wrong! I would reccomend a better reg than the 2 in 1. Maybe a scott grey reactor, or arizona. I for one, just my opinion really dont like life batts. Drop off is a big concern to me.
Sent from my LG-MS690 using Tapatalk 2
SAB Goblin 700,HeliJive 120HV V11, Bls 451's cyc,Bls 251 tail, Scorpion HKIII 4035-560, Edge 693SE, Edge 115SE, VBar 5.2 pro Full size... |
