| Main Forum - Helicopter Talk R/C Helicopters and the people who fly them. VENDOR TOPICS DO NOT GO HERE. Full Scale Heli threads go in OT please |
Ok, i have two of these on a field supply i am setting up. http://www.jaycar.com.au/productView.asp?ID=SK0979
Have confused myself with wiring it up. Three posts on the switch 1 and 2 are the same, the third is gold. Posts 1 = load, 2 = supply, 3 = neutral or earth ? with neutral, the illuminated light stays on all the time there is power to the switch, even if the switch is off. I thought it would turn the light off if the switch was off.
T-rex 450 Super KDS 450 QS SJM 400 V2 |
Reverse the power in and out wires but leave the 3rd wire the same
#3 |
misread post
Raptor 50 OS50 Hyper, Futaba 520 Miniature Aircraft Furion 450, Spartan Quark Futaba 9CHP |
#4 |
Oh man, be careful. I used to use that type of switch for 55 watt 12v fog lights on my car. I blew out 3 of them before I figured out I needed a relay.
Good thing you're not using that on a heli. Good luck. ![]()
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T. Save the flybar !! |
#5 | |
#6 |
But any normal switch, the center is the common terminal. Switch goes from center to either other pin, depending on the switch position. When using a lighted switch, they tool the light from the center pin, because of physical wiring inside the switch its near impossible to take it form the normal switched side.
Dan Pesonen FBL, Don't think about it, DO IT. mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS "Tri-Flow" I put that S*** on everything!" |
#7 | |
Ok, lucky I didnt swear at him LOL
