Old 01-30-2012, 10:52 AM   #1
lancedoze
Default Elevator control arm upgrade?
I am going flybarless and while I am at it i want to upgrade to the elevator control arm instead of the anti rotation bracket. Do I need anything else besides HN6102AF? What takes the place of the anti rotation bracket?
DX7 4 ALL
Trex 450 pro 3GX
Trex600 cf, Jazz 80-6-18
Trex 600N, O.S. 50 Hyper
lancedoze is offline        Reply With Quote
Old 01-30-2012, 02:45 PM   #2
Simes996
That's all there is to it. Did it myself last month. You might/will need to re-level the swashplate, but the anti-rotation bracket becomes surplus to requirements.
Simes996 is offline        Reply With Quote
Old 01-30-2012, 03:49 PM   #3
lancedoze
DX7 4 ALL
Trex 450 pro 3GX
Old 05-12-2012, 04:51 PM   #4
mgorgis
Hi guys,
I too want to upgrade bracket to A arm because I'l upgrade to DFC head but I have the V1 nitro which has the elevator arm at the front of the heli while the A arm is fitted at the rear side! So how is this fixed? If at all possible. Also, I can buy the HN6102QF and not HN6102AF is there a differece between these two?
mgorgis is offline        Reply With Quote
Old 05-16-2012, 05:37 PM   #5
mgorgis
Originally Posted by mgorgis View Post
Hi guys,
Question is answered by myself thanks anyway
Old 05-17-2012, 03:39 AM   #6
Simes996
So, what was the answer?
Old 05-17-2012, 04:52 AM   #7
mgorgis
Well the new A shaped arm will still be at the front just like the old one and the difference between the two spare parts is the color and I'm going with the black one :-)
Old 05-23-2012, 01:51 PM   #8
seanh
I did this mod...easy, just put it on in place of the original elevator arm. From what I recall, there was no specific modifications needed. I'll check when I get home.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910
seanh is offline        Reply With Quote
Old 05-23-2012, 02:27 PM   #9
mgorgis
Would be intresting to know what spare part nr you used
Old 05-24-2012, 11:00 AM   #10
seanh
I didn't use any spare parts. The A-arm comes with everything you need. Just take the anti rotation bracket out, take your old elevator arm off and reassemble with the new one.
Old 05-24-2012, 01:56 PM   #11
mgorgis
I meant the part nr of the A arm
Old 05-26-2012, 05:00 PM   #12
seanh
what is "nr"
Old 05-27-2012, 11:57 AM   #13
f3nix
what is "nr"
nr = number
Cheers,
Mateusz
T-Rex 250SE, T-Rex 450Pro,T-Rex 550 V2, T-Rex 600N LE, Blade mSR, Blade mCP X
DX8
f3nix is offline        Reply With Quote
Old 05-27-2012, 01:39 PM   #14
mgorgis
nr. no. number #
Old 02-28-2013, 02:27 PM   #15
leeph
Sorry to resurrect an old thread, but since I've just done the elevator A-arm upgrade, I thought I'd share my experience.
There appears to be two parts released as an elevator arm upgrade for the 600N. I got the latest part kit - which was HN6102AA - in black to match the rest of my NSP hardware.
Whilst being a bit fiddly, it was a straight swap, and absolutely no adjustment needed on any of the linkages, but then I did spend a long time during initial build getting everything 90 degrees at 0 pitch, so I guess I got that bit right. Appears to be no slop on the elevator at all, and absolutely no play on the control shaft/bell cranks - one thick shim and one thin shim were used on each side.
Nice upgrade - will have to wait until the weather warms up to test her out though! Next upgrade, flybarless - so this was partly in anticipation of that.
leeph
T-Rex 600 NSP: OS 50 Hyper, Align DS610 on cyclic, DS760 w/s9254 on tail, s3152 on throttle, RCE-G600
T-Rex 500 CF: Stock align motor and esc w/12T, Hitec 82mg on cyclic, DS760 w/9257 on tail
leeph is offline        Reply With Quote
Old 03-04-2013, 10:12 PM   #16
sixback
One additional thing I do is move the elevator servo inboard of the frames. Only requires one additional align part to provide the mounting base.
sixback is offline        Reply With Quote
Old 03-05-2013, 05:38 AM   #17
leeph
Yeah, that would make for a tidy machine - I never liked how close the back of the servo + servo wire is to the right bellcrank as it is at the moment.
What part is required for this alternate mounting - is it this? "H60183M Metal Elevator Servo Mount"
The description for this says: Use for T-REX 600N/600E/700E tail servo.
Tail servo?
leeph
Old 03-06-2013, 09:56 AM   #18
DanMcN
I had the same issue as Sixback and had to move the servo inward. The servo rod ends were binding at full travel with the servo horn. I used a carbon servo plate placed between the frame and the servo.
Gaui x5, x5, x7, Rush 750 - Ikons, DX9
FAA Reg # "DRONESSUK"
DanMcN is online now        Reply With Quote
