Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > Futaba CGY750 FBL System
Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum
Old 05-29-2012, 02:36 PM   #1
flyboydave
Default CGY 750 Gov setup help needed
Hi,
After running a gallon of fuel through my new model and having the engine run in its now decided that its time to set the gov. Now i'm at a loss before I start as the very first part in the instructions tells you to make sure the display is changed by moving the switch , now its not doing this and i'm very new to sbus, I think I have set the switch to it as in the function menu I have set ctrl se on gov, which is function 8.
Where do I go from here to get it working in all idle up's? please explain and remember I'm new to it and don't know what i'm doing!!
flyboydave is offline        Reply With Quote
Old 05-30-2012, 06:30 AM   #2
flyboydave
It's assigned switch se the same as idle up, I don't know about a condition as I don't see it on that first page on the condition menu, it's listed in the next part but that's under delay. I have no idea what the arrows mean next to the idle up and hold functions in the condition menu?
There is a gov menu in the tx, do I need to change the settings in that rather than the 750? When I looked it showed the gov inhibit in idle one and idle two, when I went to act it said need to change end points, end points of what though and is this what I need to do to get it working? Will I mess up the setup I already have if I click yes to change end points ? Why is it asking me to do this anyway?
