| Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics |
trying to bind an aR 6100e , but the RX to GT5 connections seem to preclude the use of the bind plug i. I've tried a number of combos , each time the AR6100 light goes steady like its binded but then when i turn it back on it isn't
![]() ![]() Tried binding the RX separately and through the GT5 Closest i've got is w/ the esc plugged into the GT5 [freeing up the Batt. post on the ar6100 for the bind plug] , then binding through the GT5 , when done the RX light is steady but its still not bound. Still not sure of right proceedure even. still binds to a sat. not sure if i should still be binding in Spektrum mode w/ normal Rx? Last edited by mrultralite; 05-31-2012 at 05:58 PM.. |
FRom TT , thanks guys;
Please bind your transmitter and receiver first. Then connect 3 wires from the receiver to the GT5 per the manual and set up the "receiver" to be 5ch on the GT5. |
#3 |
Got it going, had to experiment all morning to get the RX - GT5 plugs in right spots.
everything seems to be working on test stand [ i had to rest everything], but those lights in the 'gain ' column blink alot and total gain seems to be zero now or nor registering, plus the RC indicator is now an ''!''. I now have 'failsafe'! |
#4 |
Flew it and the I d-stick was now way off [low] nearly uncontrollable
