| mCP X Blade Micro CPx Helicopters Information and Help |
I've noticed several people writing about how many flights on a particular heli or particular batteries.
How do you keep track of these? Do you number your batteries? If so, do you have a system for assigning numbers? Is there "an app for that"? I'd be interested in any ideas about logging or other record-keeping. |
I # the batteries. And the helicopters as I have 2 MCPXs.
A is oldest batteries I have 1, 2, 3, 4, A 1, 2,3,4 no longer fly B is newer batteries 1, 2, 3, 4, B 3 and 4 no longer fly C is newer still 1,2,3,4 All still quite new and fly well. Then jot down anything pertinent at the end of the flight. What I practiced indoors or out. Crashes or problems. Rain or shine wind conditions.
Ron Petrolia Ontario CX2,MCX2,MSR,120SR,Rescue Heli,MCPX,MCPX-bl, B450 DX6i Now building a Hirobo shuttle 30 size To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#3 |
I have a database for HanDBase which I use on my Android phone. I keep track of helis, flights, parts lists, repairs and adjustments, crashes, etc. Never thought about adding battery info but that's a great idea.
mSRx / nCPx /mCPx BL / 130X / mQX Trex 450 Pro 3GX / Trex 500 Pro DFC AR7200BX / Trex 600e Pro DFC SK540 DX8 What is with this compulsion to put "X" in product names? |
#4 |
I have a small note pad that I log my flights in (I have 2 mCPxs) and also how many flights each battery has. I numbered my batteries so I could differentiate then.
#5 | |
Havent started logging flights yet, but am gonna start. I have the memory of a fruit fly when it comes to detail, etc.
/MSRX, MCPX, Nano, 1SQ, several 130x, Gaui X2, 300x, 450x, DX8, Harley Road King To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. "It's not getting any smarter out there, you have to come to grips with stupidity and make it work for you" - Frank Zappa |
#6 |
I use the rcFlightbook iPhone app although I have a couple of other apps... and all seem to have same functionality.
The DX8 transmitter's timer is activated by throttle, so its really easy to keep track of flight times. Some of the apps have pick-lists fields for multiple airplanes/helis, and batteries. When recharging batteries, you can log how much you put back in the battery if your charger provides the info. Battery care and culling is a part the hobby Mostly I use time entering the info as a brain break after a flight and to think about what I want to work on next ![]()
Takeoff is optional, landing is mandatory. Blade MSR, MSRx, MCPX*4, B450x+HC3SX, Protos 500 stretched+Brain, Century E640+HC3SX |
#7 |
I log all my flying sessions in an Excel spreadsheet. Date, number of flights and comments. I only note which batteries I used (they are all numbered) if they do not last as long as expected. The comments include the location, weather (particularly wind conditions), major incidents/breakages, new things tried and my general thoughts on how the session went. I have 10 batteries and use them at random to even out the wear so I can only estimate how many flights I have made with each.
I use the same log to note upgrades, changes made and general wear and tear including servo cleaning. I did wonder about logging which batteries were used in a session but I found it a chore. I have some new batteries on the way and will try to log their flights accurately. What amazes me is just how long my V2 has flown. Initially I thought that 4 minutes was not long for a flight but it adds up when you have done 200 of them. 800 minutes is 13 hours ! |
#8 |
Thank you for the comments so far; I hope there will be more.
I started out with airplanes, and quickly found there are a multiplicity of sizes and shapes. (grrrrr!) But I have several kinds of airplanes and only two kinds of helis (mSR and MCPX). I'm thinking about a numbering system to distinguish the different numbers of cells and different form factors. Since I haven't done anything yet, I can start everything from scratch. And now that I can hover nose-out, I can start my log with fewer crashes than successful flights. I hope. |
#9 | |
Would you be willing to share your database scheme? |
#10 |
On the Mcpx i justttnumbered he batteries and try tofly them in order to share the flights out.
I also note down the number of any supect packs but so far theyare all ok On my larger helis I stick a sticker on the battery and mark each flight off with a pen (like a prisoner would on the wall of his cell) Then I can track how many cycles each battery has done. |
#11 |
The database has some issues because I'm trying to implement something that doesn't seem to fit into HanDBase well. I'm going to share it on the HanDBase web site at some point, but if you don't mind a few quirks, I'd be glad to send the files to you or upload them and give you the link. One thing the Android version doesn't have that I used a lot on my TX is the ability to create forms. So the user interface is bare bones, but it's functional. One thing about the Android version... If you follow more than four links between different databases, the program crashes. I've got links all over the place so you can go from one database to another (there are 9 so far), and I've crashed it a few times, but in practice it isn't that big a deal. The HanDBase people really need to fix that one! When I get home tonight I'll upload it and post a link for you.
#12 |
For everything RC I use "RCLogbook" on the iPhone. It's $5, I think, but is awesome...especially for heli's and keeping track of batteries and their cycles. Also has a feature for maintenance reminders every so often (user programmable). Couldn't recommend it more. One other nice feature is it has a backup database stored online in case the phone gets lost, stolen, upgraded, etc.
Blade mSR - Blade mCPX v2
T-Rex 500EFL PRO - T-Rex 600EFL PRO Spektrum AR7200BX Castle Creations JR 11X DSM2 |
