| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
I'm flying a Trex 600 EFL Pro with Beast X, when I invert the heli by pulling back on the stick or sideways she inverts nicely & quickly. But when I push the stick forward she goes over very slowly & I have to make sure that I have plenty of height.
Looking at the swash plate, the travel looks even in all directions & the speed of travel seems consistant. Any ideas anyone as this has got me stumped? ![]()
---------------------------------------------------------------------------------------------------------------------------- Trex 250, Trex 500, Trex 600 NSP, Trex 600 EFL Pro, Trex 700, Beast X, Futaba Need a bigger house
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I can se that you have a Futaba. On Futaba radios the travel of the servos is done for each side. I think that maybe you have more throv back- than forwards?
#3 | |
#4 |
Swash plate travel on the ground is irrellevant. This is an FBL system and as a consequence, when sat on the ground, it will nearly always show you full travel, up to the limits set in the FBL controller itself, step L as it happens in this case. This is because by moving your stick you request an action from your heli, the FBL controller tries to deliver this, but nothing happens, so it gives more to achieve this but still nothing happens, so it gives more and more and more, until it is at full throw.
However, when you want to tune the rotation rate, or speed of rolls or flips in the air, the controller responds to the size of the Tx signal to deliver a given rate, so, as mentioned, if the ATV for forward elevator is lower than that set for backward elevator then this would result in the differential rates that you have observed, even though on the ground there appears to be no difference. Cheers Sutty
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1, FBL Trex600ESP µB, Parkzone P51D |
#5 | |
![]() I've re-done the settings on the Beast X but the weather's been cr*p here so I haven't had a chance to test it. How would I check the ATV on the forward elevator? Cheers Adam ![]()
#6 |
I think I've solved the problem.
The end points on the elevator were (somehow ) set to 50% / 100%. so I've put them to 100% on both.This should solve the issue though how the end point went to 50% is a mystery as it was setup on a new model memory. I will do a re-setup before flying & also update the firmware to V 3 whatever the latest is, but I'm away at the moment so all this will have to wait 'till I'm back on the beach
#7 |
I'll bet you have it licked.
Jeff Borowski RAMS Club President www.ramsrcclub.com |
#8 |
Hope so, haven't had a chance to test it yet as I'm away at the moment
