| Event Forum Please add your events to this forum so people know where the action is |
TriplecreekRC Riverview, FL is hosting 3rd annual helicopter funfly and AMA/F3C contest on Oct. 27~28.
Wide open filed as you see on www.triplecreekrc.com sky shot. We have electric and running water. Campers are welcomed. Nob Muraki |
We'll have Aeromed full size medical helicopter flying in for Saturday noon time.
It's going to be cool. |
#3 |
Sounds good. Will seethat we make it.
#4 |
Going to try to make it...
Nel3D.com spacecoastrcheliassociation.com |
#5 |
Here is maneuver list for Expert class.
Funfly pilots should try as well. Gonna be fun. Unknowns for Expert Class It's the same maneuver pool from last year. Expert Class Unknown List From 2007-9 19.3. Class III 19.3.1 Vertical rectangle with 360 Degree Pirouettes 19.3.2 Inverted Vertical Triangle with 180 Degree Pirouettes 19.3.3 Vertical Hourglass with 180 Degree Pirouettes. 19.3.4 2 Consecutive Axial Rolls (dd) 19.3.5 Rolling Stall Turn Plus 540 Stall Turn (ud) 19.3.6 Stall with Pullback Recovery (uu) 19.3.7 Cobra Roll with 1â„2 Rolls (dd) 19.3.8 180 Degree Autorotation (du) From 2011 Rules 19.3 Expert 19.3.1 Figure M 19.3.2 Vertical Circle with 360 Degree Pirouette 19.3.3 Inverted Triangle 19.3.4 Cuban eight 19.3.5 Double Rolling Stall Turn with Loop 19.3.6 Cobra Roll with ½ Rolls 19.3.7 Stall with Pullback recovery 19.3.8 180 Degree Autorotation |
#6 |
F3C Unknowns
F3C Unknowns lists From 2006 List SCHEDULE A (2006-2009) A1.DIAMOND.(UU) A2. INVERTED TRIANGLE(UU) A3.HOVERING M(UU) A4. ROLL REVERSAL (DD) A5. DOUBLE ROLLING STALL TURN(UU) A6. COBRA ROLL WITH HALF ROLLS(DD) A7. FLIPPING PULLBACK (UU) A8. CUBAN EIGHT(DD) A9. PUSH OVER WITH 360º PIROUETTE (UU) A10. AUTOROTATION WITH 180º TURN SCHEDULE B (2006-2007) B1. HOURGLASS 1 (UU) B2. CIRCLE WITH TWO 360º PIROUETTES(UU) B3. RECTANGLE WITH 180º PIROUETTES (UU) B4. HORIZONTAL EIGHT(DD) B5. FIGURE “M†WITH 180º STALL TURNS(UU) B6. COBRA ROLL + ½ ROLLS AND PUSHED FLIP(DD) B7. DUAL FLIP WITH HALF OUTSIDE LOOP(UU) B8. PULL-UP WITH 360º INVERTED PIROUETTE(DD) B9. SQUARE LOOP WITH HALF ROLLS(UU) B10. AUTOROTATION WITH TWO 90º TURNS(DU) SCHEDULE C (2008-2009) C1. HOURGLASS 2(UU) C2. PIROUETTING HEXAGON(UU) C3. RECTANGLE WITH 4-POINT PIROUETTES (UU) C4. 4-POINT ROLL(DD) C5. TWO REVERSE OUTSIDE LOOPS(UU) C6. KNIFE EDGE COBRA ROLL WITH 450º PIROUETTE(DD) C7. FIGURE M WITH 540º STALL TURNS(UU) C8. HORIZONTAL EIGHT WITH ROLLS(DD) C9. VERTICAL SPIKE(UU) C10. 180 deg. AUTOROTATION (UU) From 2010 List SCHEDULE P P1. FIGURE M WITH HALF PIROUETTES(UU) P2. SEMI CIRCLE WITH PIROUETTE(UU) P3. DIAMOND 3(UU) P4. CUBAN 8 WITH HALF 4 POINT ROLLS(DD) P5. PULLBACK WITH BACKWARD ROLL (UU) P6. COBRA ROLL WITH ¾ PUSHED FLIP(DD) P7. CANDLE WITH TWO HALF ROLLS, HALF PUSHED FLIP (UU) P8. TWO OPPOSITE TWO POINT ROLLS (DD) P9. INSIDE LOOP WITH PIROUETTE (UU) P10. AUTOROTATION WITH TWO 90º TURNS(DU) SCHEDULE F F1. CIRCLE WITH 360º PIROUETTE(UU) F2. INVERTED TRIANGLE 2(UU) F3. OVAL 1(UU) F4. CUBAN 8 WITH PUSHED FLIP(DD) F5. PULLBACK WITH 3 HALF LOOPS AND 2 TAIL TURNS(UU) F6. COBRA ROLL WITH PIROUETTE(DD) F7. TWO LOOPS WITH HALF ROLLS (UU) F8. PUSHED FLIP WITH HALF ROLLS (DD) F9. VERTICAL 540º FLIP(UD) F10. S-AUTOROTATION (UU) |
#7 |
Several people asked me the AMA class manoevers.
For those never done AMA/FAI contests, take a look at the rule book and give it a shot. I guarantee you'll have fun. Helicopter rule book: http://www.modelaircraft.org/files/2...elicopter1.pdf Sportsman http://www.modelaircraft.org/files/R...iagram2011.pdf Advanced: http://www.modelaircraft.org/files/R...iagram2011.pdf Expert: http://www.modelaircraft.org/files/R...iagram2011.pdf Again, there is no separation for FB and FBL in this contest. Also expand extra machine usage for Unknowns for Expert and F3C class. Nob |
