Old 06-19-2012, 12:10 AM   #1
peterkjr2009
Default HK500GT Tail Help
So I've had my 500 for nearly 1.5 years now, replaced the main, feathering and tail shafts with align ones, and has been flying great all this time...Then I decided to mess with it, and now I have a little wag I can't get rid off.
Basically I noticed the tail grips were getting a bit sloppy, I rembered reading a thread about gently filing down the hub to stop the grips rocking etc.
Did that, put the tail back together, all seemed great, took it for a flight, wag wag, wag, I adjusted gain up and down, tried using delay, nothing worked.
Fired the heli up on the bench, tried moving tail push rod, by hand, it was nearly impossible to move, even at a fairly low speed, which confused me as tail felt so smooth, I've replaced the hub and grips with align ones, now the wag is down to about an inch either way, but I just can't get rid of it. Also when I flicked to. idle up the other day, something made a screeching sound. I've since had the whole tail system apart to check bearings etc. Anyone got any ideas, I'm stumped, I should of just left it alone. Lol
peterkjr2009 is online now        Reply With Quote
Old 06-19-2012, 03:38 AM   #2
xpftp
belt to lose .. might need new belt.. old one strached out ..
peterkjr2009...I flicked to. idle up the other day, something made a screeching sound..
B400 gotta love the old girl / 250 / 500 ..
Turn Up The Juice. See What Shakes Lose
xpftp is offline        Reply With Quote
Old 06-19-2012, 10:17 AM   #3
peterkjr2009
I took the whole tail apart last night, and the belt and all bearins seemed fine, flew again today, still wagging, I. guess I need to strip it down, and check for vibes as i go.
Old 06-19-2012, 02:08 PM   #4
xpftp
ok if belt is ok . what gyro do you use and other basic info if you can please .
Old 06-19-2012, 02:11 PM   #5
peterkjr2009
gyro is an align gp750 and tail servo is align ds520, running 6v.
Old 06-19-2012, 02:17 PM   #6
xpftp
http://rc.runryder.com/helicopter/ga...750_Manual.pdf
try reseting the hz to it i think its called .. 1520 to 760 or other way around so on .. maybe it forgot after bein no power so long
Old 06-19-2012, 04:53 PM   #7
ddj74
While the heli is not powered up try moving the tail by hand...if stiff then that's why its wagging. As the slider moves on the tail shaft and binds it causes over correction when it gets past the area it's getting stuck at and vise versa. Could also be a bad setting in the gyro and not finding the correct center.
T-REX 700 DFC v3, AR7200BX, ICE2 160HV,DC-UP MARK II
MKS HBL950 & MKS HBL980, GRYPHON EXTREME REGULATOR
POWERED BY THUNDER POWER LIPO'S
ddj74 is offline        Reply With Quote
