| Blade 450X Blade 450X Helicopters Information and Help |
for those of you that have or is flying with the stock servo's DS76 and DS76t and what is your experience with them ? Please chime in, Reason for asking is first day the servo that sits under the batt red wire came undone shorted out HH sent me a new one installed it 2 days later that new replacement done the same thing it froze up, and my tail servo froze up
I went a purchased a new tail servo had no problems since but now this new servo stopped working today the one under the batt...Im bewildered honestly...Idk if its the beast x but Im running all the settings from the manual..so far it will be 3 new servos under the batt cause Ill go buy another one and 1 tail servo but the tail is holding up good so far its the one under the batt thats keeps going out Any input ?
Mcpx v2 - B450 X (DFC Soon) - AR7200BX - DX6i |
#2 | |
But the servo itself is great.....just check the wires.... FWIW |
#3 |
I lost my elevator servo around flight 45- resulted in bad crash. Took the opportunity to change all cyclic servos to HiTec 5065MG.
I just lost my tail servo this past weekend on flight #75- good thing I did a control check before lifting off so I didn't fly with it. I had noticed the two flights prior that the tail was beginning to show a bit of wag in inverted hover. I replaced it with a stock servo- they are fast and light. Both failures were the same- the servo motor just didn't have any power any longer. It would turn, but it always needed "help" to get started moving. I think one of the FETs is burning out on the board.
Blade 130X- My cul-del-sac flyer. Blade 450X w/MSH Brain - My Ferrari T-Rex 600 EFL Pro w/SK-720, KDE600XF & SK-GPS - My BMW T-Rex 700 HV DFC w/VBar, Kosmik 200 & KDE700XF - My muscle heli |
#4 |
I did check them and they all have good connection idk whats going on
#5 | |
I also noticed a tiny bit of wag inverted to, but I just replaced the tail servo with a stocker brand new and still have a tiny tiny bit of wag inverted, I ll try making sure my links and servo are close to 90 as possible. Other than that this servo thing is killing me lol
#6 |
My basic point is to check things......
Just because it's "BNF"... I can't speak of knockoffs or adaptations of the 450X......as I have 3 certified, original, pedigried 450Xs......and all the tests that I perform have been done so on "the HH/E-Flite" 450X..... From what I have tested, among other things, the 450X is a great buy for the buck..... I certainly will get the 500X, when available, and I hope HH and company go bigger....600X/700X For me, it's easier to check an "ARF" heli, than to fumble with all the "washers"......if I have a choice.....and as an EE, I can at least check the electronics.....and pass on whatever info... FWIW |
#7 |
I have had 2 of the DS76's die. The first one I thankfully catch before taking off but the second one died just after takeoff resulting in a lot of damage. Also every time the blades touch the ground at least 2 of the 3 cyclic servos strip a gear.(The fact that mine is FBL makes this even worse)
I am now using the Solar D654 servos from hobbypartz.com. They are digital and metal geared. I have about 100 flights and 1 crash on them and they are working great. After 3 crashes with them they will pay for themselves since they are $10 a piece and three DS76 gear sets is about that.
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL |
#8 | ||
Prior to tare down I found the cause of my issue was "me not setting the heli up outta box" and the problem I had was the servo was binding the link to the swash hence making the servo over work itself and burn up...Since re-doing the beast x setup from start to finish and quadruple checked everything over went for a test hover things went perfect ! Stuck a fresh pack in 15 mins later and ripped the sky up Had to go into menu L I think it was to redo the endpoints on the servos Quote:
