Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Old 06-21-2012, 05:09 AM   #1
baja5b
Default Hobbywing RPM sensor
Hi Guys,
Just picked up a HW 120 HV and would like to know I connect the rpm sensor. I am not using Vbar or govenor.
I'll be using 3GX and fixed end point throttle
baja5b is offline        Reply With Quote
Old 06-21-2012, 06:29 AM   #2
Mr Nice Guy
If you are not using an external governor then there is no reason to hook up the RPM sensor. It is used to let a vbar/skookum etc know how fast the motor is turning so it can govern the throttle.
Knock on the sky and listen to the sound
Mr Nice Guy is offline        Reply With Quote
