| Aerodynamics, Physics and Engineering Aerodynamics, Physics and Engineering Discussions |
I have been flying rc helis for 6 years now
And I noticed through flying lots of them that some are less sensitive to the wind than others For example the outrage fusion 50 is less sensitive than my logo 600 To tell u the truth the outrage is much more stable in the wind than the logo 600 Off course I mean 3d flying ( funnels , tic toc ....etc ) --- I am here: http://tapatalk.com/map.php?jamqsy |
How heavy are the two helis?
Like planks disc/wing loading affects stability in the wind (higher is better). For a heli more weight also makes a difference (regardless of disc loading) as there is more inertia for the wind to overcome. Assuming they are both FB, its less of an issue with FBL helis.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh |
#3 |
Thanks for replying
Both my logo 600 which weigh 4.2 kg with 623 mm edge blades fbl and my goblin 700 which weigh 5.1 kg and the sab 690 mm are so sensitive to the wind but the outrage fusion 50 is so stable in the wind that I couldn't believe it when I tried one although its almost the same weight as the logo and it uses the same blades and that's what got me to wonder about the design Sent from my iPhone using Tapatalk |
#4 |
Since they are fbl, what differences are there in setup? Ie gyro, servo and settings.
#5 |
All the same servos jr 8717 working on 5.5 volts and all vbar with almost identical setups
#6 |
The outrage and the logo runs at 2200 hs
And the goblin runs at 2230 hs Sent from my iPhone using Tapatalk |
#7 |
That shouldn't be then, assuming both gains were optimized.
It's possible that damping design differences are the cause. Also if one Heli has perfect phasing and the other doesn't, that can be a cause too. My Tdr was jittery and a bit hard to hover precisely until I optimized the phasing for the specific blades. |
#8 | |
that has to be FBL setup.. as nothing short of a 50+ MPH wind is going to move a 700E anywhere you dont want it to go.. with a properly setup Vbar 5.2+ wind is non existant on any 600-700 heli for the msot part. We fly in sustained 30+ down here during the spring and early summer and none of my large birds fight the wind at all.. hell I fly the 450 in 25ish winds with no issues.
SAB USA Field Rep, Skookum Field Rep, Team Lynx. Goblin 700, Goblin 630, Goblin 500 |
#9 |
Ok Here is a video to show what I am talking about
It was a 35 km+ wind and gust up to 40 something At the end of the funnel u will c that the heli drifts like there is no tomorrow youtube.com/index?desktop_uri=%2F&gl=EG#/watch?v=USnRwUogcK8 --- I am here: http://tapatalk.com/map.php?j0qb1p |
#10 |
Tomorrow I will attach my vbar file any comments will be appreciated
--- I am here: http://tapatalk.com/map.php?uo2224 |
#11 | |
can you please explain ? |
#12 |
Different blades lead or lag different amount. The head has fixed phase, usually 90. This means on one set of blades, if elevator servo moves, the Heli perfectly moves in pitch only. Gyro corrections are thus applied perfectly by the blades, achieving rapid stabilization of a destabilizing event eg wind
On a different set of blades that lag say 3degrees, here's what happens in simplified explanation. Elevator servo moves, Heli moves cosine3 in pitch, and sine3 in roll Now gyro has to correct the roll error by using aileron swash But then the Aileron swash actually causes a bit of pitch. So what happens is a wobble, or precession movement of the head or body with destabilizing events. Not only does it slow down the recovery of control, but also limits the max gain usable, component wear. If you do some quick stabs of either collective or rudder, or do a rapid stop, and see a wobble in either head or body, that means the phase is out a bit. My experience with the Tdr is, at 4deg out, the Heli feels a bit unsteady. Piros wobble noticeably rather than being flat. Gain can't be turned high before body wobbling even at hover. Now that it has 4deg of swash lead (ie blade lags 4deg), perfect flying machine.... I'm in total awe of it! |
#13 |
Any update?
#14 |
I have been tinkering with an HK450V2 NOBAR projekt with a little bit of success. I am still in the "hunting the best blades" phase (no pun intended) and was curious as to how i determine the lag of a particular set of blades? This way I can optimize the phasing for each set tried. Im using an old school mechanical swash driver, seperate from rotorhead, so phasing adjustments should be possible. On a side note: does blade lag occur with any noticeable effect on the tail (i realize they woud both lag the same amount, if at all).
#15 | |
#16 |
First make sure your fbl is perfectly aligned to frame
Then, start with 0deg phase, which is default, turn the cyclic gain up until you have wobbles at hover. If the wobble is single axis only, usually airleron, then no phase adjustment needed. If the wobble is an ellipse or circle, then correction is needed. Usually advancing. Last edited by kimmik; 07-24-2012 at 02:34 AM.. |
#17 | |
#18 |
Skookum has a setting. It's a fbl adjustment. Vbar too I'm sure, no
#19 |
Not sure about 3gx or bx
#20 |
With the beastx you can adjust the phase with the micro settings software. You will need the USB adapter.
Don Newman MAAC #82859 Align 250 Pro DFC, Tarot 450, EXI 500, Chaos 600 |
