| 120 SR Blade (eFlite) 120 SR Helicopters Information and Help |
so first off I will welcome myself. my 120 should be arriving shortly in the mail. not new to to heli's but new to 120. I have done my searching about mods and what not to do on here. I already got some 250 skids and going to make my own boom supports, do the flybar mod. not trying to make a performance machine out of this one, more just somthing fun and worry free to fly around in the back yard.
so my real question, for those that are using the nano tech 600mah (already bought 6 of them), and not using the stock charger, what amp are you charging them. I got a 306b i-charger that I am going to be parallel charging all 6 of them with but can't find any info on what kind of charge rate to throw at these batteries.
Son of Rvfr trex 500 fbl......piloting rave 450....sold, 450 pro.....sold, trex 450 v1......sold |
1C charge would be 0.6 amps.
There are some really nice charging rate and time calculators at 2BFly. http://2bfly.com/tools/ |
#3 | |
The best way to get around To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 | |
You should charge them at .3 amp for the first couple of charges then at 1c or .600 amps. |
#5 |
I seem to remember reading somewhere that the Nano-techs can handle up to a 5C charge rate. I'd never go that high myself, I stick to 1C or if I'm in a hurry I'll bump it up to 2C.
*EDIT Just double checked HK's website. Very weird that the 600mah version doesn't have it's specific charge rate listed but the literature indicates that some batts in their nano line can handle up to 15C charge rates. Doesn't really tell you anything concrete, but you should be able to establish some sort of baseline for whatever you're comfortable with from that... *EDIT2 Charge rate on their 300mah Nanotech is listed as 10C, probably safe to assume the 600mah is comparable. |
#6 |
Just remember if you are charging 6 of them as a 1s6p battery, 3600mah would be a 1c charge. 7200 would be 2c.
I have no use for that kind of charging setup, make an adapter so you can charge 6 of them as a 6s1p battery, use balance mode. Now you can monitor exactly what each cell is doing as it is charging. I've seen a charger time out when one cell in that kind of parallel setup wouldn't reach 4.2v, it would have kept charging forever and never hit termination voltage. You'd have no idea why or which cell is causing the problem. Much safer in series as a bad cell will give you a cell count error at startup, won't let you charge a screwed up battery. Then 600mah would be a 1c charge rate etc. You charge time will be much shorter also you are only putting 80% of 600mah back in as opposed to 80% of 3600mah. I charge 4 at a time this way balanced as a 4s pack in about 20 minutes. |
