Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Titan X50E
Titan X50E Thunder Tiger Titan X50E Helicopters
Old 03-02-2012, 07:12 AM   #1
audio131
Default wrong distance spec on pinion install
hi. in the manual it says 18mm from mount to end of pinion . if u set it at 18mm it will be too long of a distance and u will have u remove it and reset the pinion closer to the motor.. i found the 16.5 mm is perfect... you will understand when u see the manual.
audio131 is offline        Reply With Quote
Old 03-03-2012, 12:30 AM   #2
ranma103
cheers bud thanx for the info.
My Fleet: Gaui NX4 FBL (SK-540) / T-Rex 700N FBL OS GT15 HZ (SK-540) / Heli X G700 FBL (CGY-750)
ranma103 is online now        Reply With Quote
Old 06-23-2012, 04:05 PM   #3
simonarvestrand
Sounds right. in my new x50e it says 16,5mm
simonarvestrand is offline        Reply With Quote
