Old 06-23-2012, 01:54 PM   #1
coredump
Default Help: Flashing MCPX, really broken 3 in 1 wanted
I want to download some custom firmware into the MCPX
3 in 1, which means, write your own FBL control to have
adjustable tail gain etc.
I have make enough progress understanding how to talk
to the receiver chip. See here:
http://www.helifreak.com/showthread.php?t=427772
I also make a PDI plug to download the firmware into the
atxmega16a4 on the 3 in 1. I can read the device fuse and
lock bits fine. I believe I just need to click "erase device"
and then I will be able to down my own firmware to the 3 in 1.
The catch is that, I will never able to get the original firmware
back.
But it seems such a waste to destory a perfectly working
3 in 1. Here is where I am asking for help.
Does any one has some really broken 3 in 1 board they
don't want so I can buy it cheap? I do mean really broken.
Things like board do not bind is fine by me because I can still
use the MCU to do some programing with the gyro etc.
I can even pull the receiver signal from the good board.
I also perfer the V2 board because V1 board are good for
BL conversion, even broken one has some value to some
of us. If you have a really broken V1 board, I might able to
fix it up for you.
Note: Burning FETs are easy fixable by a few members here.
PM me if you have some broken 3 in 1.
coredump is offline        Reply With Quote
Old 06-23-2012, 04:41 PM   #2
cp11
Can't you just read the device and save it as a backup, or is it copy protected?
You can always remove the AVR and replace it with a blank one
cp11 is offline        Reply With Quote
Old 06-23-2012, 06:17 PM   #3
Drivinfast247
My buddy has a board that broke the corner of the pcb.
Drivinfast247 is offline        Reply With Quote
Old 06-23-2012, 08:39 PM   #4
coredump
cp11:
As I post on the receiver chip thread, the MCU on 3 in 1 has the lock bit
set to disable all read/write. The only way to download firmware is to erase
the device. It is design to protect the original firmware.
I can replace with a blink one, I even bought a few and clean up the conforming
coating on one of my board. But Still it is a lot of work to take the MCU out
and put a new one back on. Using a broken 3 in 1 is much simpler.
Drivnfast247: Thank you. Will send you PM.
Old 06-23-2012, 08:41 PM   #5
Mega Stumbler
How many do you want? I think I might have a few.
Sent using Tapatalk. Please forgive/ignore autocorrect errors.
Mega Stumbler is online now        Reply With Quote
Old 06-23-2012, 11:07 PM   #6
coredump
Thanks Mega, that is great. If a board is consider broken by you,
it is definitely broken enough for me that I don't feel guilty flashing it.
If possible, I would like to get a few to cover different board revision.
Thanks again.
Old 06-23-2012, 11:50 PM   #7
cp11
Too bad about the code protection, but it's expected I guess. Are you writing it in assembly, or C? You should find a tiny speaker and program it to play songs or a siren while you fly!
Old 06-24-2012, 02:58 AM   #8
coredump
HH will definitely use a MCU that protects their firmware. It is expected.
I am glad it is not like the avr mega series which I need to solder 20 pins
to just erase it. Done that for the walkera ESC.
I will be writing in C and thinking in assembly code that C generates.
I have update some guess about the MCPX debug port in the receiver thread:
http://helifreak.com/showthread.php?t=427772&page=3
Old 06-25-2012, 04:27 AM   #9
coredump
Here are some notes on mapping the V2 MCU pin out:
I use the port number rather than chip pin number. You need
read the datasheet to map them back to chip pin number.
The port number is easier for programming.
portA:
[0:2] not used. In V1 it is the gyro analog input.
3: motor ground plug. OCP input.
4: monitor battery Vcc/2
5: main motor output voltage measure
6: tail motor output voltage measure
7: MCU voltage monitor (3v /2)
Port B:
0: connect to porta_7, MCU voltage.
[1:3] Not used
Port C
0: I2c data for gyro
1: i2c clock for gyro
2: Debug port serial out
3: Debug port serial in
4: tail motor pwm
5: main motor pwm
6: LED, push to light it.
7: not used.
port D:
0: Right servo PPM
1: Elervation servo PPM
2: Left servo PPM
3: Not used
4: Receiver data interrupt.
5: Receiver data SPI data
6: Gyro Interrupt (That is the line has receiver data plumb into it)
7: Receiver SPI clock
Port E: not used.
