Go Back   HeliFreak > R/C Helicopters > Event Forum
Event Forum Please add your events to this forum so people know where the action is
Old 06-16-2012, 08:06 PM   #1
ymuraki
Default Triplecreek RC Tampa, FL Fall classic Fun-fly
TriplecreekRC Riverview, FL is hosting 3rd annual helicopter funfly and AMA/F3C contest on Oct. 27~28.
Wide open filed as you see on www.triplecreekrc.com sky shot.
We have electric and running water. Campers are welcomed.
Nob Muraki
ymuraki is offline        Reply With Quote
Old 06-16-2012, 08:08 PM   #2
ymuraki
Default Full size medical heli visit
We'll have Aeromed full size medical helicopter flying in for Saturday noon time.
It's going to be cool.
Old 06-30-2012, 05:29 PM   #3
im4711
Sounds good. Will seethat we make it.
im4711 is offline        Reply With Quote
Old 07-19-2012, 02:18 PM   #4
Nelson Rodriguez
Going to try to make it...
Nel3D.com
spacecoastrcheliassociation.com
Nelson Rodriguez is online now        Reply With Quote
Old 08-23-2012, 07:20 AM   #5
ymuraki
Default Unknown list for Expert Class
Here is maneuver list for Expert class.
Funfly pilots should try as well. Gonna be fun.
Unknowns for Expert Class
It's the same maneuver pool from last year.
Expert Class Unknown List
From 2007-9
19.3. Class III
19.3.1 Vertical rectangle with 360 Degree Pirouettes
19.3.2 Inverted Vertical Triangle with 180 Degree Pirouettes
19.3.3 Vertical Hourglass with 180 Degree Pirouettes.
19.3.4 2 Consecutive Axial Rolls (dd)
19.3.5 Rolling Stall Turn Plus 540 Stall Turn (ud)
19.3.6 Stall with Pullback Recovery (uu)
19.3.7 Cobra Roll with 1â„2 Rolls (dd)
19.3.8 180 Degree Autorotation (du)
From 2011 Rules
19.3 Expert
19.3.1 Figure M
19.3.2 Vertical Circle with 360 Degree Pirouette
19.3.3 Inverted Triangle
19.3.4 Cuban eight
19.3.5 Double Rolling Stall Turn with Loop
19.3.6 Cobra Roll with ½ Rolls
19.3.7 Stall with Pullback recovery
Old 08-23-2012, 07:21 AM   #6
ymuraki
Default F3C Unknowns
F3C Unknowns
F3C Unknowns lists
From 2006 List
SCHEDULE A (2006-2009)
A1.DIAMOND.(UU)
A2. INVERTED TRIANGLE(UU)
A3.HOVERING M(UU)
A4. ROLL REVERSAL (DD)
A5. DOUBLE ROLLING STALL TURN(UU)
A6. COBRA ROLL WITH HALF ROLLS(DD)
A7. FLIPPING PULLBACK (UU)
A8. CUBAN EIGHT(DD)
A9. PUSH OVER WITH 360º PIROUETTE (UU)
A10. AUTOROTATION WITH 180º TURN
SCHEDULE B (2006-2007)
B1. HOURGLASS 1 (UU)
B2. CIRCLE WITH TWO 360º PIROUETTES(UU)
B3. RECTANGLE WITH 180º PIROUETTES (UU)
B4. HORIZONTAL EIGHT(DD)
B5. FIGURE “M†WITH 180º STALL TURNS(UU)
B6. COBRA ROLL + ½ ROLLS AND PUSHED FLIP(DD)
B7. DUAL FLIP WITH HALF OUTSIDE LOOP(UU)
B8. PULL-UP WITH 360º INVERTED PIROUETTE(DD)
B9. SQUARE LOOP WITH HALF ROLLS(UU)
B10. AUTOROTATION WITH TWO 90º TURNS(DU)
SCHEDULE C (2008-2009)
C1. HOURGLASS 2(UU)
C2. PIROUETTING HEXAGON(UU)
C3. RECTANGLE WITH 4-POINT PIROUETTES (UU)
C4. 4-POINT ROLL(DD)
C5. TWO REVERSE OUTSIDE LOOPS(UU)
C6. KNIFE EDGE COBRA ROLL WITH 450º PIROUETTE(DD)
C7. FIGURE M WITH 540º STALL TURNS(UU)
C8. HORIZONTAL EIGHT WITH ROLLS(DD)
C9. VERTICAL SPIKE(UU)
C10. 180 deg. AUTOROTATION (UU)
From 2010 List
SCHEDULE P
P1. FIGURE M WITH HALF PIROUETTES(UU)
P2. SEMI CIRCLE WITH PIROUETTE(UU)
P3. DIAMOND 3(UU)
P4. CUBAN 8 WITH HALF 4 POINT ROLLS(DD)
P5. PULLBACK WITH BACKWARD ROLL (UU)
P6. COBRA ROLL WITH ¾ PUSHED FLIP(DD)
P7. CANDLE WITH TWO HALF ROLLS, HALF PUSHED FLIP (UU)
P8. TWO OPPOSITE TWO POINT ROLLS (DD)
P9. INSIDE LOOP WITH PIROUETTE (UU)
P10. AUTOROTATION WITH TWO 90º TURNS(DU)
SCHEDULE F
F1. CIRCLE WITH 360º PIROUETTE(UU)
F2. INVERTED TRIANGLE 2(UU)
F3. OVAL 1(UU)
F4. CUBAN 8 WITH PUSHED FLIP(DD)
F5. PULLBACK WITH 3 HALF LOOPS AND 2 TAIL TURNS(UU)
F6. COBRA ROLL WITH PIROUETTE(DD)
F7. TWO LOOPS WITH HALF ROLLS (UU)
F8. PUSHED FLIP WITH HALF ROLLS (DD)
F9. VERTICAL 540º FLIP(UD)
F10. S-AUTOROTATION (UU)
Old 09-08-2012, 07:55 PM   #7
ymuraki
Default AMA class rule book
Several people asked me the AMA class manoevers.
For those never done AMA/FAI contests, take a look at the rule book and give it a shot. I guarantee you'll have fun.
Helicopter rule book:
http://www.modelaircraft.org/files/2...elicopter1.pdf
Sportsman
http://www.modelaircraft.org/files/R...iagram2011.pdf
Advanced:
Expert:
Again, there is no separation for FB and FBL in this contest.
Also expand extra machine usage for Unknowns for Expert and F3C class.
Nob
