| 550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#21 | |
Maintaining helis is part of the hobby. Anyone who thinks they should just throw their heli together and forget about it needs to reevaluate the hobby. So yes, I am capable of that. What kind of question is that? LOL I'm not going to argue with you because obviously you don't know how to read the manual sitting there telling me that there is a problem running 2700 hs. If something happens to some poor soul at 2700 hs take it up with Align because that's what the manual states. Try hooked on phonics it will teach you how to read the words and numbers. So you continue to run your 2200 hs and I hope that heavy boat flys well enough for you not to bog and "kill" you. To each their own. By the way, I see you keep saying a 550 can kill you. A 450 can kill you so be sure not to go around acting like anything smaller than a 550 wont kill you. Safety first! Don't fly your heli directly in front of you if you cant control it. It is a helicopter, take it up in the air.
Synergy E7 Trex 700E DFC Goblin 500 Blade 130X Hold My beer and watch this ;-) |
#22 |
Guys to each their own, some people like flying with lower headspeeds and some like to run it as high as safely possible. There is no need for name calling, this is supposed to be a fun hobby.
Logo 500se VBar Pro 5.3 Align Trex 700 DFC HV Vbar Pro 5.3 Align Trex 500 EFL Pro Mini Vbar 5.3 Outrage Fusion 50 6s Vbar Pro 5.3 |
#23 |
I agree. I took my jab and I will refrain any further negative post regardless of what comes at me. Happy flying to all and God bless.
#24 |
is it possible for me to run a cc100 with the governor with 550 mains? I read that 2250 is about the limit for the motor or esc, i cant remember.......my guess is that you all are running fixed end points up at 2400+ rpm. Thanks, I just cant wait to crash this! lol : )))
#25 |
A new 550 pro and I can barely get it in the air when the tail starts oscillating side to side like crazy.
I have checked everything out, balanced everything in the tail. Reduced the tail gyro to 25 % and increased the collective throughout the curve. I need a bit of help and advice on this please |
#26 | |
#27 |
Yhanks for the advice Raydee. The wag is as though the gain is too high, the gyro is overshooting and then correcting, overshooting correcting.I thought Ihad it fixed by changing the main shaft ( factory supplied) At least now I can hover, until I use the tail then it starts all over again. Would a higher or lower head speed help. I will do what you advised , then try again. Ill let you know
#28 |
check the gain channel settings in your Tx, it sounds like you might have it set differently. How do you have it assigned?
Carl Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544 |
#29 |
Did you have a crash? You said you changed the main shaft? Why did you decide to do that? Check to make sure your feathering shaft isn't bent or has play. The good ole' mCPX use to do the same thing if bent or not tight.
#30 |
i had same exact felling kde600 xf 1175kv when flying on 12pwm, try 8 it will remove the lag that 12 have.
Sanwa SD10G ,T-Rex 550.V2 FB Kde 600XF ,T-Rex 450 Pro.V2 3GX + KDE ,M120D01 ,V120D02S To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#31 |
Thank you so much for the advise. When you say lag, what do you mean?
#32 |
anythibg less than 2600 i DO NOT LIKE! i run 100 tc flat in idle 2 and get just over 2700 for about 1.5 min then it drops to around 2650 the rest of the flight, i get 7 min flight with 3.78 v per cell. that being said i check every screw and all the feathering shafts before every flight as we all should do......
about the wag i have found that the tail slider rod holders(plastic on the boom) need to be oiled alot i got the wag and oiled them and presto it went away, just something to chew on but anywaz love this bird!
control crash expert! blade 450x, edge blades, more coming. trex 550e v2, hc3sx, cc100, edge 553, cc bec pro To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. trex 550e v2, 7200bx, cc100, cc bec pro, edge 523trex 450pro v2 7200bx, dx8 edge blades, hs5065 mg, kds 450sv, |
