| Flybarless Helicopter Systems CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3, Gyrobot, SK360and AC3X |
My tail is bouncing on piro stop left(counterclockwise) only. Clockwise piro stops seem to be fine. It was much worse before until I went down on my Tail P gain, but I can't get it to stop perfect without bouncing.
This is on my Stretched 6sMini Protos i have just built. I have had the ZYX on two other 450 helis without any problems at all. any help would be appreciated. I'm kinda new at messing with the PID gains.
William Alees Rush 700-Kosmik 160A + KDE 700XF-495 Synergy N5C & E5-600 Protos 500 |
I had the same problem as you. Turn down your tail d gain and it should help. I have mine set at 0 and no bouncing.
My Aerial Photography ==> To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Ecilop AP quad + NAZA, Sony Nex 7, and a bunch of other goodies Blade 450 3D FBL w/ Tarot ZYX | DX6i, Custom Blade 130X w/ Tarot ZYX-S |
#3 |
thank you sir. I will give it a try next time I fly.
#4 |
Are you using the 8 degree tail blade pitch into main blade rotation recommended by John_NZ?
Phoenix, mCPX, B4503D, B450zyx420, B450zyx440, DX8 |
#5 |
#6 | |
#7 |
You should play around with your settings in the ZYX to get the piro bounce to stop both ways. Read here about all the settings http://www.toyrecycler.net/?p=23279
#8 |
I found that you really need some D gain for clean stops. Try setting D to 15, then decrease the Tail Deceleration value for the side where it bounces until it stops without bounce. If you decrease it too much, the stop will look mushy. Most people find they need different L/R decel values to get clean stops both sides.
Fly first ask questions later. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0 MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0 Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion |
#9 | |
#10 |
Hey Wbefield, when you say you got it worked out, what settings did you end up changing to stop the tail bounce. I have the same problem, I get hard stops when i turn the nose left, but when i turn the nose right, the tail stops and then bounces back about 5 - 10 degrees.
Thanks. |
#11 | |
Start with P=80, I=50, D=10. Set your deceleration rates 27 on CCW piros and 22 on CW (this is the bouncy side). If you still have bounce, decrease the CW deceleration, if it's too mushy, increase (1 point at a time).
#12 |
I had the exact same problem, I had to lower the "I" gain and it worked great after that.
