| Compass Model Helicopters Compass Model Helicopter Discussion |
My 6hv has rusty screws, do all compass models have this? Is it a concern?
#2 | |
I just spray some Q20 and wipe off when it becomes visible
Lotus7 Compass 6HV Compass 600E |
#3 |
Its not just a compass thing. All of my byrds are like that.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ):> Compass 7HV, Atom 500 "Some men just want to watch the world burn" |
#4 |
Had my 7HV from launch, flew in spits of rain and high humidity during the build up to the rain season, but no issues with rust on my bolts (just doing a rebuild atm). But I haven't flown it in the salty air near an ocean yet.
Compass Atom 7HV, Scorp HK3 4035 hand wound by Mauro - 6x7x1.32 YY 430KV, CGY750 Beam E4, 6S, looking for a new FBL unit, BX is getting removed! Formerly owned - Blade mCP X V2 - Blade 400 FBL BeastX |
#5 |
My 7HV has this too on the bolts holding the control arms. I now store my heli in the bag for it with silca gel beads and that has helped. I also add a few drops of Clp to those screw heads after wiping it down for the day too.
Team Synergy VP Racing Fuels Team Scorpion |
#6 |
Spoke too soon, found 2 bolts with some minor surface rust.
#7 |
And I am damn sure the bolt will not just rust away during the active life of the heli
BTW , surface rust can be a good thing , it can form a patina which which inhibits deeper rust
#8 |
You will have bought the latest and greatest helicopter long before rusty screws will ever be a structural issue but, yes, it is not attractive. If you like to keep things looking nice, use a Q-tip and a good protectant on the screws. Q-tip keeps it from getting on everything. I use an aircraft corrosion product, can't remember what it's called but anything will work.
#9 |
I have not run into this.
I will look at some of my older Compass machines this week, to see if there is any rust present. The Atom 500, 6HV and 7HV are clean.
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
#10 |
This comes from a lack of oil on the bolts during shipping, you may see this with tail hubs as well.
Give me a lever long enough and I'll move the world... ):> Team Helifreak! |
#11 |
It'll happen wether they are rusty when received or not. As soon as we degrease them with acetone for using threadlocker, they will begin to rust unless kept oiled.
= R To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. b43 = Team Compass Support |
#12 |
All my helis except my Aligns have rust on the screws. Maybe Aligns aren't made with real metal. LOL
#13 |
I smell a conspiracy
"bbrfst" ( )( )
Atom 500 VBar (Takes a licking), MCPx 2s (Flying To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ), Atom 7HV-Bar (Flying LARGE!!) |
#14 | |
they are plated...old ones used to be chromed , those were realllyyy bad!
Warp, 6HV LED, 7HV, Rush ^^^^Team Compass^^^^ Nankin Hobby "Tis the season to get everything ready" |
#15 |
You dont have to use acetone on them prior to threadlock. If you are using the real Henkel Loctite, example 243 as I use then that has emulsifier or what you call it. Similar technology as how you get oil to bind with water. So the thread locker will stick very well even if there are a little bit of oil on it. Its enough to dry it off with a dry cloth prior to applying Loctite...
- Futaba 14FG | TT Mini Titan V2 BeastX | Compass Warp 360BeastX | Logo 600 SX V-bar | Outrage Velocity 50N2 V-bar - |
#16 |
I use the proper stuff and still acetone the feathering shaft screws
#17 |
I have a couple of friends that keep their helis in their garages and they have rusty screws. I keep mine in my air conditioned house and mine are not at all rusty. This is regardless of brand.
Knock on the sky and listen to the sound |
#18 |
Over here if you "have a rusty screw" it means you like the older woman if you know what I mean fellas
6hv (fb) 7hv DX8 |
#19 |
No rusty screws but I got a rusty tail hub today.
Ah well, it spins so fast the rust will just fling off.
Scott Compass 7Hv - Synergy E5 - Logo 600RCHeliCanada.com -Rep Next: 6Hv Ultimate |
#20 |
I don't have any on my 3D plus but this really comes down to how the bird is stored and cleaned. I use gun oil to prevent rust on the screws (Remington oil with Teflon lubricant) and also I us a break free gun cloth that has silicone on it. My bird is stored in my basement
Compass 3D plus (WildCat fuel 30%) OS 55HZ-H Hyper with GP Exhaust Energy 57 Align DS610'S and DS650 Specktrum DX7 Specktrum AR7100 W/Revlimit |
