Mikado V-BAR Mikado V-Stabi/V-BAR Flybarless System Software and Hardware Support |
07-04-2012, 06:26 AM | #1 (permalink) |
Satellite synchronization error
I've never seen this error on any of my other Vbars in the past, " Satellite Data out of Synchronization", however I have been getting tons on my logs. I am running latest firmware on Full size Blue and new Silverline sensor. I'm using a DSM2 DX7 and 2 DSMX satellites, bound as Specktrum Digital Center.
So far I have tried rebinding but the error continues to come up. Satellites are BN as are the cables. Any ideas? I have attached event log.
Team Rotorquest/ SAB Heli Canada |
07-04-2012, 12:32 PM | #2 (permalink) |
Anyone?
Sent from my iPhone 4S using Tapatalk
Team Rotorquest/ SAB Heli Canada Last edited by mtymyk; 07-05-2012 at 05:36 AM.. |
07-05-2012, 10:32 AM | #3 (permalink) |
After much back searching, I have yet to see any posts regarding the specific " synchronization" error. After some more troubleshooting, I believe I solved the issue. Seems once I set my Jive from 6v to 5.6v on the bec , the error is no longer showing up.
... Nope, error is back, showed up on first flight Sent from my iPhone 4S using Tapatalk
Team Rotorquest/ SAB Heli Canada Last edited by mtymyk; 07-05-2012 at 05:45 PM.. |
07-10-2012, 12:48 AM | #4 (permalink) |
This is just a shot in the dark since I haven't the foggiest what that error means, but have you tried re-binding?
Also seeing a lot of antenna switches... So it's either not liking your satellite placement, sat cable coming loose or a sat going bad. |
07-10-2012, 05:18 AM | #6 (permalink) |
I have tried rebinding several times, no difference. Also have repositioned the satellites, but error still shows up.
I have also tried different satellites and sat cables, neither made a difference. I am running DSM2 radio w/ DSMX satellites all bound to " Spektrum digital centre" And Mr.Mel, heli is a Diabolo.... Sent from my iPhone 4S using Tapatalk
07-10-2012, 06:32 AM | #7 (permalink) |
Does it have belt?
Static is always a possibility The error is new in 5.3 as the decoder was re-written but the error is the same as checksum error. |
07-10-2012, 07:12 AM | #8 (permalink) |
Ok thanks Mr.Mel, it is a belt, I'll check the ground on the boom, even give the ground a continuity test, I'll report back on testing.
