Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 7HV
Atom 7HV Compass Atom 7HV Model Helicopter Discussion
Old 07-11-2012, 07:16 AM   #1
TwinTurbo95
Default How do you guys wire up your reciever packs for HV servos?
Hey guys,
This is my first HV servo set up. I will be using a 2S Lipo.
On all my previous non-HV set ups I've been using a LiFe battery with a switch, like this:
http://www.horizonhobby.com/products...arness-SPM9530
Can I use this switch with HV servos or do the HV servos pull too many amps?
If I can't use this switch then what can I use? I thought about soldering two servo wires together connected to a deans and just plug both servo ends into the reciever. But I would rather have a switch.
Compass 7HV - BeastX - MKS HV servos
T-Rex 500 FBL - BeastX - DFC - Scorpion
Blade 300X
TwinTurbo95 is offline        Reply With Quote
Old 07-11-2012, 07:24 AM   #2
djamgils
I wouldnt even use that switch for lifepo...
you want at least 2 and preferably 3 servo plugs for power and no switch in between.
Best would be a skookum soft switch power bus or a perfect regulator safe switch.
JR Nex E8, and E12 Hiroki Ito Edition
djamgils is online now        Reply With Quote
Old 07-11-2012, 07:53 AM   #3
TwinTurbo95
A Skookum power bus came with my kit, but I'm OCD and hate a ton of wires.
Just soldering two servo cables together with a deans on the end is enough?
Blade 300X
Old 07-11-2012, 08:08 AM   #4
djamgils
yep that could work, although 3servo plugs is better (only 2.5A continuous per plug) and deans suck imho. So you are better of with EC3 or XT60 or.... but not deans.
Old 07-11-2012, 08:17 AM   #5
TwinTurbo95
I'll order me a Perfect Regulator switch. But to maiden this weekend I'll just have to make me a cable
Blade 300X
Old 07-12-2012, 10:21 AM   #6
Jamesppp
I have a very clean install with the Skookum soft switch Powerbus
I'm using a bind plug in the switch position for better visibility
I shortened the Sk wires between the Sk 720 and the Powerbus
I'm powering 4 outrage Torq servos and using a Futaba S bus as satellite
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900
Jamesppp is offline        Reply With Quote
Old 07-12-2012, 10:31 AM   #7
TwinTurbo95
Blade 300X
Old 07-12-2012, 10:40 AM   #8
Jamesppp
Originally Posted by TwinTurbo95 View Post
I have a pic posted on the Skookum board so I can't post it here
I tried to copy/paste a link to the post but couldn't make it work using my phone
EDIT here is a link to the crappy phone pic
http://helifreak.com/showpost.php?p=4035902&postcount=1
