| Mikado V-BAR Mikado V-Stabi/V-BAR Flybarless System Software and Hardware Support |
Edit: Solved. See reply.
Ok, some weird stuff, had a V-Bar gov with a HeliJive 120+ HV on a Goblin, it worked ok, but recently switched to an YGE 160 HV due to other reasons. Plan to run the V-Bar on an unregulated 2S LiPo, but am also running it on 4.8V during testing (YGE ProgCard II setup). The requested headspeed is showing up as 0 in the software, however, the current (actual) headspeed seems to be measured correctly by the V-Bar, just by looking and listening to the head on the bench. Throttle values don't coincide with actual headspeeds as before. Can actually manage to get headspeeds on the bench way beyond the maximum entered headspeed too. The only reason I can think if, is calibration scales or zero/end-points being shifted. However I've tried calibration with both a linear 0-100 curve and collective control, same issue. Also doesn't explain the requested headspeed not showing though. Anyone? Logfile included at the bottom. ![]() Logfile: http://rzavelli.home.xs4all.nl/stuff...requested0.pdf
http://www.xs4all.nl/~rzavelli/rc_heli.txt |
I'm a retard.
I've pressed reset on the gov. 1 tab, but failed to (re)check preset and output channels afterwards.
