Old 07-19-2012, 01:44 AM   #1
iborg
Default Disappearing blades
Hi Folks
I did find them, but, think I am missing bits.
It just didn't look right in the air, so I was coming down when I had my blades explode in opposite directions.
I think I am missing a couple of bits and would like to check with you guys, what should be there.
I think it should be-
(blade grip) (rubber damper) (metal washer) (rubber damper)
(HEAD)
(rubber damper) (metal washer) (rubber damper) (blade grip)
With the feathering spindle through the lot.
I think I am missing two dampers
Thanks for any help
Philip
mPC X -
CopterX Black Angel - currently trying to stop it being just a lawn dart !
iborg is offline        Reply With Quote
Old 07-19-2012, 01:47 AM   #2
03Bugeye
ya, replace blades sooner next time.
03Bugeye is offline        Reply With Quote
Old 07-19-2012, 02:01 AM   #3
Tasteles
Originally Posted by iborg View Post
Hi Folks
(HEAD)
Thanks for any help
Philip
Actually it should be
(blade grip) (metal washer) (rubber damper)
(HEAD)
(rubber damper) (metal washer) (blade grip)
and the step in the metal washer goes towards the blade grip.
Tasteles is offline        Reply With Quote
Old 07-19-2012, 02:01 AM   #4
UKHeliBob
The sequence should be :
Blade grip (ball race in each side)
Metal washer (ridge outwards)
Rubber dampener (recessed in the head)
Head
Use Loctite on the feathering spindle screw when you re-assemble it.
UKHeliBob is offline        Reply With Quote
Old 07-19-2012, 02:03 AM   #5
Tasteles
lol, beat cha!
Old 07-19-2012, 02:24 AM   #6
iborg
Thanks guys
I was mistaking the ball race for a second damper. Also, thanks for pointing out the step/ridge in the washer. Not sure I would have noticed that.
I was intending to locktite the screw in the spindle.
Oddly enough, the purple locktite that I have came in a blue bottle and the blue locktite came in a bottle that almost looks purple! Go figure!
Have fun
mPC X -
Old 07-19-2012, 02:58 AM   #7
markus45
Head
I had thought of using locktite on spindle/screw when putting back together but how can you do that when such a pita just to get the s##t of a thing back together at the best of times.
markus45 is offline        Reply With Quote
Old 07-19-2012, 06:08 AM   #8
iborg
After having it flick out of a pair of needle nose tweezers twice!! and somehow finding the sucker, I tried balancing it on the end of a Phillips head screwdriver which has a wide enough base to stand upright on its own.
I then used a fine blade driver to apply a little locktite, removed the excess by very gently touching with a tissue.
I could then carefully bring the blade grip down over the screw and hold it in position in the bearing, with the driver.
Then carefully slide onto the feathering spindle and screw together.
All happy now, I hope!
mPC X -
Old 07-19-2012, 07:33 AM   #9
UKHeliBob
Put one side together and have the FS sticking out the other side. Put the stepped washer on the shaft. Put the Loctite into the end of the FS by putting a small drop on the end of a cocktail stick.
Now slide the other blade grip on. The rubber dampeners will stop the FS from sliding back through the head. The FS screws used to be magnetic but now don't seem to be so you cannot usually get them to stick on the end of the screwdriver by magnetising it. I usually use a very small blob of grease on the end of the screwdriver and hold the screw in place with that.
Start the screw into the Loctited thread on the FS but do not push too hard.
The easiest way to tighten the FS screws is to hold the Phillips head still by putting the screwdriver on it, holding the combined screwdriver and blade grip in one hand and tightening the other end of the FS.
Old 07-19-2012, 12:10 PM   #10
MiataJohn
Your Dentist can be a great source of c/a or threadlock applicators. See if he/she will save their old picks (used to clean teeth) for you. Some of them have very fine ends. just soak em in bleach to kill any bacteria. My Dentist Autoclaves them before he gives them away.
2x Stock mCPX, 1 B/L HP05 mCPX Blade 400 3x HS65mg, GY520, Align 425
Mini Protos 3x HS5065mg, AR7200BX, JR290
Trex 500ESP,Parkzone T-28, All on Dx6i
AMA 732104
MiataJohn is offline        Reply With Quote
Old 07-19-2012, 01:48 PM   #11
Coco66
Finally! Then I was not drunk the last time I replaced the spindle and had to invent a trick to keep the screw on the screwdriver!
I actually used a small ball of Patafix.
2 X Blade mCP X v2 ♦ night fly Blade mQX ♦ LadyMQX hybrid ♦ Blade 450X w/telemetry and Loc8tor ♦ Blade Nano CP X ♦ Compass Warp 360 w/AR7200BX, (2nd) Koby 40, DS92A+, DS95i, telemetry and Loc8tor ♦ Spektrum DX8/DX6i
Coco66 is offline        Reply With Quote
Old 07-19-2012, 04:18 PM   #12
UKHeliBob
The screw is so small and light that it even sticks if you just lick the end of the screwdriver !
Old 07-19-2012, 04:53 PM   #13
iborg
I'm now kicking myself that I didn't put the locktite in the end of the spindle!
mPC X -
Old 07-20-2012, 01:18 AM   #14
Coco66
LOL thinking about the guy licking a screwdriver and wife suddenly popping up and wandering
Old 07-20-2012, 09:48 AM   #15
alex7703
These are what you need. They work awesome for all kinds of uses with the MCPX. scrape the brush material off one for a perfect spindle loctite applicator...
http://www.ebay.com/itm/Microbrush-t...item22fd859c33
alex7703 is offline        Reply With Quote
Old 07-20-2012, 06:00 PM   #16
MiataJohn
www.plantraco.com has them in 3 sizes and 2 quantities (10 and 100)
AMA 732104
Old 07-20-2012, 09:37 PM   #17
markus45
Would the blue threadlock be the correct one to use on f/s / screw ?.
cheers mark.
Old 07-21-2012, 12:57 PM   #18
MiataJohn
Yes.
AMA 732104
Old 07-21-2012, 09:08 PM   #19
stablehover
Lay your screwdrivers/tools on an old motor or use a piece of magnet and rub your chosen tool on it before use. Like the magnet you stick on your fridge.
stablehover is online now        Reply With Quote
Old 07-21-2012, 09:48 PM   #20
new bee
I agree,
My favorite screwdriver lives on a magnet when not in use.
new bee is offline        Reply With Quote
