| Gasser Helicopters Gasser Specific Discussion |
Is there any good threads that show the differances between the two? Durability, longevity, weight? Thanks.
Found this as well. Any one have experience with it?? Helibug Open-Source with Gasbug-RC for Trex700
#3 |
http://helifreak.com/showthread.php?t=328029
and Helibug Core 7 http://helifreak.com/showthread.php?t=297775 I researched on gasser for a while too. Decided to go the Helibug route because I want RC format motor instead of PUH
Blade mCPX | TRex 550e | TRex 500DFC | DX8 Helibug TRex 600DFC 17T, HC3sX, Hanson 26 Pro Plus, GV1/SG, Century V5 Helix G700 17T, HC3sX, CY F270, GV1/SG, Century V2, Generator |
#4 |
Are you referring to just the conversion kits - Helibug or HWC (Century) for the T600'a and T700's.
As far as choosing one related to the PUH or H engines, because there seems to be more "tweaked" versions of the H series of Zenoah engines, like you see in this thread, so the HWC may well be worth seriously considering as it already comes with a very heavy duty clutch and auto bearing system. http://www.helifreak.com/showthread.php?t=410028
Leisure-Tech Rep Last edited by MotorRotor; 07-22-2012 at 11:39 AM.. Reason: spelling |
#5 |
Thanks for all the links. I am trying to decide if I need to go Helibug or HWC. Seems like HWC have more high performance engines. The new Helibug Open-Source frames look realy good though. And they use the Zenoah clutch systems. I'd like to go with the 26 to 29cc engines.
#6 |
I have the Helibug 700 RC version and the HWC600 with 321puh
Both helis are great! However, Ali's (Helibug) quality is exceptional.. the G10 frames were cut to perfection and everything was spot on.. The century stuff is a little rougher but still quite good.. I think the helibug 700 frame is stronger as the HWC conversion has a few narrow points in the frame.. I can't comment on the Helibug open sourced stuff thou as i only have the 700 conversion of his. The Century kit had a bad pinion (which they replaced) and a wobbly clutch bell - but i must have just got a bad one as it's a radikal 30 one and there are many of them in use. The century bearings also seem a little sus as I got a notchy one in the kit and also had a few notchy bearings in my Radikal G20 I had previously.. But there arn't too many bearings in the HWC conversions so that's not really a problem anyway.. Parts outside of the US are a nightmare to get from Century - just took me 11 days and about 10 or more emails just to get a simple order processed from them... so not reall happy there but they are good once you finally get onto them... (Natalia there has excellent customer service - they need to give her a pay rise...) on the other hand - Helibug have updated their website and i looked for a few weeks and parts were not listed there either.. I just looked now and the parts page says "Comming soon" - so that could be about 2 months now so that's a major Slip for Ali as everything else he does is spot on.. Not that i'm after parts but if I was i would like them listed on the site to simply order and not have to go through another series of email to grab some. You are in the states so Century parts will be a non-issue for you i guess.. With regards to performance engines - no difference between the 2 as there are performance RC and PUH format engines that fit both.. I'm sure you will be happy with either one
DX7 Mode-1 | T-Rex 250 | EP200SE V2 | Tricopter | Quadcopter 450 pro 6s fbl 3X1000 | 450 pro fbl beastx | Schweizer 300C Gasser Scale |T-Rex550e 600 vbar | Aeolus 50 HeliX T-Rex700 fbl Gasser | HWC600 321puh Gasser fbl| Henseleit TDR Last edited by jockstrap; 07-23-2012 at 05:01 PM.. Reason: typos |
#7 |
Thanks for all the good info. Thats what I'm looking for.
