Old 07-20-2012, 02:22 PM   #1
Shanes
Default Replacing pinion on 450 3D
Hello!
I'm hoping you can tell me how to go about replacing the pinion on my 450 3D. It came off in flight. Have a new one.
Do I take the motor out with the 4 screws?
Many thanks!
s
Shanes is offline        Reply With Quote
Old 07-20-2012, 03:01 PM   #2
FuntanaS
Yeah, you will have to take the motor out of the heli and also take the motor mount off of the motor.
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL
FuntanaS is offline        Reply With Quote
Old 07-20-2012, 03:04 PM   #3
kavic5150
Post
Usually a good idea to disconnect all 3 motor wires to keep from bending them while you work on the motor.
Yep, pretty straight forward procedure. Remove all 4 motor mount bolts. You might not need to remove the motor mount if the pinion meshes with the main gear and that grub screw is accessable.
Use some blue loctite on the grub screw before installing it. As long as the motor shaft has a flat spot you shouldnt need any other adhesives to install pinion.
You probably already know this, but if the motor spins the wrong way when you get it all assembled, just swap any 2 motor wires.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is offline        Reply With Quote
Old 07-20-2012, 03:08 PM   #4
Shanes
Big thank you!
Old 07-20-2012, 07:13 PM   #5
5307thBP
No need to remove the mount, just the motor. 2 screws from the bottom, removing the ESC makes access easy with a good set of hex drivers.
5307thBP is offline        Reply With Quote
Old 07-24-2012, 08:04 AM   #6
Shanes
Ack!
It appears that the shaft on the motor that the pinion attaches to is what broke. Buy new motor?
Old 07-24-2012, 11:31 AM   #7
gdawgs56
Oh that stinks. I think u do have to buy a whole
New Motor. If you do u should get the 440 motor since it has a little more
Power for $5 More
TEAM HELIPROZ
450 FBL: Scorpion -8 motor, Tarot ZYX Fbl
130X: HPO8, DS35, Lynx, Rakon, KBDD, Fusuno, DIY mods
NANO CPX BL: SOLD
gdawgs56 is offline        Reply With Quote
Old 07-24-2012, 03:45 PM   #8
Shanes
Thanks - will do. Why on earth would it break like that after about a dozen flights?
Booooooo!
Old 07-24-2012, 04:33 PM   #9
gixster
personally i wouldn't spend any more money on the 420 or the 440 from eflite, they wear out fast and you cant get replacement shafts.
If you are going to get a new motor i would get a scorpion, or the re-branded scorpion "NextD" motors. Much higher quality and they have replacement parts available.
The scorpions go for $70-$80 and the nextD motors are about $55
Trex 550e DFC (V Bar,Scorpion HKIII 4025-1100, Rail 556 / 96, CC Edge 100)
Trex 450 DFC (MSH Brain, Scorpion 2221-8, Rail 326's, CC Edge lite 50)
Futaba 14SG, DX6I, Phoenix 4.0 , Real flight 6
gixster is online now        Reply With Quote
Old 07-24-2012, 05:12 PM   #10
chambers
I was reading somewhere that you could also use the BL450MX motor from align, its only 50 bucks. Some of the guys here may know more on it.
chambers is offline        Reply With Quote
Old 07-24-2012, 05:22 PM   #11
Shanes
Good info. Thanks!
Old 07-24-2012, 05:28 PM   #12
FireDoug
Shanes,
I would not pass go or collect $200.00 before you Call Horizon Hobby and customer service and share with them this story, they are usually very good about product support.
Best Regards
Doug
I am becoming a better Heli Mechanic than Pilot.
Blade CX2, HBFPV2, Blade mSRx, Trex 450 Pro FBL, Blade mCPx, Blade 400 FBL, Blade 450 3D FBL , NANO CPX, 130X - DX8
FireDoug is offline        Reply With Quote
Old 07-24-2012, 06:39 PM   #13
Skidpad
Originally Posted by FireDoug View Post
Shanes,
Best Regards
Doug
I completely agree! Approach it the right way and you will more than likely receive a new motor for free.
If not, let me know as I have a new 420 I'll sell.
Fusion 50, Blade 450 3D/FBL; mCPX BL, DX8
Skidpad is offline        Reply With Quote
