Go Back   HeliFreak > R/C Helicopter Support > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
Old 07-27-2012, 03:00 PM   #1
Michaelinpr
Default Align 700M with CC 80HV OK?
I am waiting for my new Scorpion 4025-550 to get here and it doesnt look like is going to be here to get it up and running again for Sunday. For some reason I have an Align 700M motor lying around even though I have never owned a 700 size bird. Saw a good deal and got it on an impulse buy.
Now I see many guys using the 700MX motor with the CC80HV but I have yet to see anyone using the 700M which is the original version of the MX. I have read that the MX is much more efficient and see that it weighs much less.
Will I be ok to run the 700M on the CC80HV?
Since I only have 13 tooth 6mm pinion for my fusion, I know that the head speed will be significantly lower than normal being a 510 Kv motor. I have been wanting to try running a lower head speed anyway for a while. I like the sound and the way it flies and with the extra torque of a 700 motor I figure I should be ok for bogging.
Sound like this will work?
FUSION 50 FBL, Scorp HKIII-4025-550/Scorp V 130,610's, V Bar/650
GAUI XB5-EXTREME 12s
, Scorp HK-4025-550/CC 80HV, 610's, V Bar/650
AleeS RUSH 750-KDE-700XF-395/YGE160HV, RJX FS0521HV's, IKON/RJX FS0521HV
Michaelinpr is online now        Reply With Quote
Old 07-27-2012, 04:28 PM   #2
Chris Sexton
The amps will be ok. I ran a 700mx in one of my fusions while my outrage motor was down.
Bird is light enough. I am running a 80amp and a 4035-560 on my new goblin 630.
Team Synergy/Team Scorpion
Chris Sexton is online now        Reply With Quote
Old 07-30-2012, 08:54 AM   #3
BaconRaygun
A bigger motor won’t necessarily draw more amps... if anything, it should draw less considering the increase in torque.
You will be just fine with an 80A ESC.
~Outrage~ Fusion 50 (FB) ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team Boca Bearings****Team LYNX Heli Innovations**
The member formerly known as Vicovaludemero
BaconRaygun is offline        Reply With Quote
