Old 08-09-2012, 02:40 AM   #21
blackout19
It's nothing to do with the signal getting through the canopy or not. When the heli is nose in to you, facing slightly to the right, you would end up with both leads from the 7200BX and one from the sat being shielded by the carbon frame. Just from a safety point of view, even if you only lose the signal for a second, the time it takes for the AR7200BX to re initialise would see your heli in bits on the floor, or worse if it was heading towards people at the time.
TREX 700e DFC HV-Ikon FBL | TREX 500 EFL Pro-AR7200BX | TREX 450 Pro V2/Tarot V2 DFC-Align 3GX 3.0
blackout19 is online now        Reply With Quote
Old 08-09-2012, 05:19 AM   #22
Steemo
Originally Posted by blackout19 View Post
...even if you only lose the signal for a second, the time it takes for the AR7200BX to re initialise would see your heli in bits on the floor, or worse if it was heading towards people at the time.
+1000000
T-Rex 700E DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro | T-Rex 500 DFC Pro AR7200BX
JR DSX9 LE Mode 2
Steemo is offline        Reply With Quote
Old 08-10-2012, 03:57 AM   #23
Steemo
Thought I'd post pics my latest wiring and electronics arrangement.
ESC on the bottom of the frame isn't ideal in a crash but if it got killed I'd have an excuse to get a CC 75A.
I used to conceal all the wires in the frame but have opted for a tidy arrangement that allows the boom block to be easily removed.
ID:	339318   Click image for larger version
ID:	339319   Click image for larger version
JR DSX9 LE Mode 2
Old 08-13-2012, 08:29 PM   #24
lazsyss350
I've got some pics here, take a look http://helifreak.com/showthread.php?t=443900
Trex 700e v2 fbl, 2x Synergy E5-s6, Trex 500pro fbl, Fusion 50 FBL , Mcpx, Ncpx, JR x9303
lazsyss350 is offline        Reply With Quote
Old 10-06-2012, 02:06 AM   #25
muscleflex
Wires everywhere!
muscleflex is offline        Reply With Quote
