| Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters |
I am assembling a mini Titian. I have everything like the pictures so far, but it seems to be that the swash goes down for positive pitch and up for negative? Is this correct?
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation |
Location: Gone. Too many assholes here and I am one less.
Yes that's correct.
#3 |
When I get to that point, should the swash lean to the left when I give it right aileron and so forth?
#4 |
No. When you lean left, the swash should tilt left, and vice versa.
That should be changed in your Swash Mix settings, depending on what tx you're using. |
#5 |
+1, once set up properly you will love the M.T. They fly larger then they are and bank like they are on rails. Just love mine, and will love it even more once I find the damm vibe.
B400(retired) Mini Titan V1 Radikal G20 |
