Old 09-17-2013, 08:41 PM   #1
Josh S
Default Flight time on trex 450 L
What kind of flight time are u guys getting just got my kit yesterday and was looking what flight time to u to break in my batteies
Josh S is offline        Reply With Quote
Old 09-17-2013, 11:46 PM   #2
isogloss3d
Everyone has their preference for pack break in procedure. I fly my packs down to 3.8V per cell (resting voltage) a hand full of times. Try starting at 3 minutes and adjust accordingly.
- Eric
Compass Atom 6HV, KDE 600XF-530 motor, CC Ice2 HV 80, Torq Servos, BeastX
MSH Protos 500, Scorpion/YGE, Brain
GAUI X3 6S, Xnova 1860, HW 50A V3, MKS DS95, 8910A+, BeastX, Belted Tail.
isogloss3d is offline        Reply With Quote
Old 09-18-2013, 09:38 AM   #3
michael88997
I have GA 1200 packs and in a 3 min flight I was using around 640mah from the packs and that was semi aggressive flying, tic tocs, big air stuff that sort of thing
michael88997 is offline        Reply With Quote
Old 09-19-2013, 07:38 PM   #4
daybed07
3:30 leaves me with 25% battery. And thats with pro class 3D (not to toot my own horn) LOL
daybed07 is offline        Reply With Quote
Old 09-19-2013, 10:20 PM   #5
Josh S
Default Trex 450 L
Cool good to have a starting point on fly time
Old 09-20-2013, 07:04 AM   #6
Team-MAYHEM
4:00 here... Using 1300's at 85% throttle
Marshall Scalisi
Team-MAYHEM is offline        Reply With Quote
Old 09-26-2013, 01:42 AM   #7
daybed07
Wondering if anyone has figured out how to get another minute or so of flight time with the 1300mah batts. I've calculated my head speed to be just above 3000 and as stated in my other post, I'm only getting 3:30 with 20-25% left. Flying with 85% flat TC. Doesn't seem like the head speed should drain the battery so fast but by the time I start having fun it's time to land.
Team turnigy
Team microheli
Team lynx
Team KBDD
Team CastleCreations
Old 09-26-2013, 09:59 AM   #8
DominicD
The Capi
I am trying to have mine complete for this weekend. My target is 2700-2800 HS, hope to get 7min. Ill let you know how that works out. Flying style and collective management plays a LARGE role in how much flight time you get.
DominicD is online now        Reply With Quote
Old 09-26-2013, 10:41 AM   #9
SMOKEMASTER60
Good luck with that 7 min I got between 3.5 and 4 min at 85% just sport flying it for my first flights. I think once I start smacking it around it will be 3.5 min max, but a really fun 3.5 min
TREX 800 PRO DFC, Trex 700, Velocity 50, Fusion 50, Outrage 550, Align Trex 450L BLADE 180 QX
Team iKon Rep // HALO BLADES
DX8 with Telemetry // Pheonix Simulator
SMOKEMASTER60 is offline        Reply With Quote
Old 09-26-2013, 11:36 AM   #10
DominicD
The Capi
I had a 6s 450 350mm machine about 4 years ago, i was able to get 6min back then.
Old 09-26-2013, 11:49 AM   #11
SMOKEMASTER60
Awesome, I would be interested in some help on how to get better flight times out of my 450L. I want it to be pretty fast and powerful still. Any tips
Old 09-26-2013, 11:52 AM   #12
DominicD
The Capi
I am having a killer week at work so I am struggling to finish this build. This machine is a hassle to wire to be honest, there is no space between where the wire exits the servo and the top bearing block , come on.
Old 09-26-2013, 12:12 PM   #13
michael88997
the problem with this machine is your limited to 1200-1300mah packs currently so unless you get a different pinion and slow it way down stock you don't get too much flight time
there is very little space, the front left servo wire can be routed on top of the back servo and then go down next to the tt gears. the servo on the right can follow the frame down on the other side of the tt gears. just strap them all down so they don't get sucked in
Old 09-26-2013, 01:37 PM   #14
DominicD
The Capi
Not my first rodeo
Old 09-26-2013, 01:55 PM   #15
SMOKEMASTER60
I found mine to wire up pretty nice if you put your unit on the top. I have a BUG mounted underneath.
Old 09-26-2013, 02:07 PM   #16
DominicD
The Capi
My problem isn't with that, I am putting my BX up there too, my problem is with the cyclic wires being crushed by the upper bearing block.
Old 09-26-2013, 02:15 PM   #17
SMOKEMASTER60
Agreed, that worries me too. Hoping it doesn't rub a hole in one
Old 09-28-2013, 08:57 AM   #18
Team-MAYHEM
just dremel a little slot on the bottom of the bearing block if this isn't your first rodeo...problem solved
edit: that sounded a little brash...not attacking you, just my sense of humor
Marshall Scalisi
Old 09-28-2013, 10:32 AM   #19
Lompma
"the problem with this machine is your limited to 1200-1300mah packs currently so unless you get a different pinion and slow it way down stock you don't get too much flight time"
Could you redo the holes on the canopy for larger batts? I know it ruins the canopy but it sounds like this heli could be a battery killer. My 4S Mini Protos tortured my 4S batts to death running a 3800 HS with 353's.
Mini Protos 4S, Logo 480 Stretch, Logo 400SE
Protos Max V2, Synergy E5, Goblin 570 12S
Lompma is offline        Reply With Quote
Old 09-28-2013, 10:55 AM   #20
DominicD
The Capi
Why on earth would you run that much hs ??
