Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 30/50
Thunder Tiger 30/50 Raptor 30, Raptor 50 Helicopters
Old 10-05-2005, 06:01 PM   #1
ColinB
Default Infinivation Dampers
Where? Not here!
I received a set of Infinivation dampers with the tuner kit (harder O-Rings) today. The heli now has almost no wobble what so ever with any cyclic inputs! The wobble is now the same as the Vibe's and (1)Stratus that I've flown (very little). As you can probably guess, I’m a happy camper!
I highly recommend these dampers for anyone with an R90 SE (they seem a bit hard for the weaker plastic head block) or with a metal hub. They are very smooth around center and don't tend to wobble at low head speeds, including the end of an auto. The o-ring setup allows the head to be soft-ish around center and then very solid once you teeter the head a few degrees.
The dampers are available at East Coast Extreme helis. I’m going to order another set after I hit the post button Awesome product.
Just thought I’d share my experience,
Colin
ColinB is offline        Reply With Quote
Old 10-14-2005, 07:34 PM   #2
Hitch-Hiker
They have a version for the 50 out now also
Jeff Swartz
Hitch-Hiker is offline        Reply With Quote
