Old 11-02-2012, 12:49 AM   #21 (permalink)
hey stolla,
I've tried both methods red and blue. As you pointed out really depends on motor and wire O.D. I really like what the blue method provides as you mentioned. Still undecided which I prefer. Right now its blue cause that what I'm use too.
I may change my other Pyro with the 1.4 mm. If I can buy the shaft on the Pyro "black edition" then less chance of snapping that shaft.
I'm sure the new Pyro 750 will change things for sure with some of the new addition's too that motor which look very interesting. Like the larger shaft and the use of nomex paper on the edge of the stator.
Off all the motors I still find the scorpion with the nomex paper the best way. Don't really care for the epoxy coating a specially on the pyro. Not very consistent plus those sharp edges on the stator is not fun to work around. One small error and you can crack the coating or nick the wire's.
copper % on this current motor 6+7 is the same as the 5+5 with 1.4 mm .
Question: As anyone have any experience rewinding a Pyro 600 ?
Working out some specs and pretty close to a method but still would like to hear from others.
cheers
HeliFX is offline        Reply With Quote Quick reply to this message
Old 11-12-2012, 08:52 PM   #22 (permalink)
Here is set of Pyro just completed. Both 6+7 1.25 YY 513 n/spec.
One thing to note for those doing these motors regarding the rewinding. I've found the carrier has a flange which is dangerously close to the wire's and coluld cause a short after some use under vibe.
So some dremel work and some nomex paper should be used.
seems like they didn't bother removing that scoop on the carrier. Not a cheap motor so why they didn't have no idea.
I suspect the Pyro 800 may have the same issue and flange on the carrier.
ID:	365738   Click image for larger version
ID:	365739   Click image for larger version
Old 11-12-2012, 09:07 PM   #23 (permalink)
I know which is mine.
Looking forward to running this thing
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 11-12-2012, 10:37 PM   #24 (permalink)
The winding looks like .....candy
Justin Harris It is better to measure 10 times and cut once, than to cut 10 times and measure once.
Sponsored by :
KONTRONIK, OPTIPOWER, PRC, CANOMOD
jhheli is offline        Reply With Quote Quick reply to this message
Old 11-12-2012, 10:50 PM   #25 (permalink)
Old 12-09-2012, 05:03 AM   #26 (permalink)
Man, y'all are true motor nuts.
I think it's time for a new hobby learning this stuff. Because I'm tired of not really knowing what's going on instead of listen to what everyone else says
Team Minicopter , and USA X-era distributor
misskimo is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 09:22 AM   #27 (permalink)
Great, now get ready for lots of reading, sore fingers, late nights and THEN the satisfaction to fly your own creation and to feel the POWER you created!!
Welcome to nutville!!!
VControl
Old hand at Planks
Peter
Old 12-09-2012, 11:56 AM   #28 (permalink)
Heli G is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 12:15 PM   #29 (permalink)
You guys that wind your own motors are nuttier then the guys that live down in the test forum.
Screw It, I'm gonna fly.
VControl, Neo, Hobbywing, Goblin 570(s)
povern is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 02:56 PM   #30 (permalink)
the benefits completely out weigh the sore fingers and all efforts to rewinding your motors.
Its the one single most important component the heart and soul of your heli that will produce results in performance.
A lot more then bling out and spending cash on shiny parts that produce zero performance.
Its not everyday you find the likes of Dr.Ralph Okun who has contributed his wealth of motors and to better the experience of all hobbyist and at the same time learn something new.
DIABOLO: PYRO 800 Kv510 YY (built by HeliFX),MKS, Vbar 5.3 + YGE160HV, JR 11X DMS || GOBLIN 570: HKIII4025 1.5mm YY Kv 620 12S(built by HeliFX),JR 8917HV, Vbar 5.3, Heli JIVE v13 || Mikado LOGO550SX v2 https://sites.google.com/site/helifxmotors/
Old 12-28-2012, 10:45 AM   #31 (permalink)
Default Pyro 700 6+6YY 1.32mm
This Pyro 700 is 6+6YY 1.32mm for n spec 540rpm/V
It has 69% more copper compared to standard Pyro 700-52.
Raptor E700: PowerDekker Pyro650, JR DS8925HV & SPG01, 12s, Vortex VX1, Kosmik160, Jeti DS-16
_Dekker is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 10:48 AM   #32 (permalink)
really nice work!
a true masterpiece.
powercroco is offline        Reply With Quote Quick reply to this message
Old 12-28-2012, 11:23 AM   #33 (permalink)
Hey Ralph I love your signature
"everything I wrote may be completely wrong because of I'am only a bloody layman and not a studied professional german engineer!"
Old 12-28-2012, 11:23 AM   #34 (permalink)
Nice work .... Dekker
Old 12-28-2012, 12:21 PM   #35 (permalink)
I hope, there is no linguistic mistake in it - I'am not a native.
Old 12-28-2012, 12:58 PM   #36 (permalink)
nope ... its perfect
Old 12-29-2012, 02:29 AM   #37 (permalink)
That signature cracked me up.
Maybe replace studied with registered.
Old 12-31-2012, 08:59 PM   #38 (permalink)
Actually, I like the way studied reads... powercroco isn't just a studied theorist, he has the ability to turn the theory into reproducible results!
Todd Moriarty is offline        Reply With Quote Quick reply to this message
Old 01-05-2013, 05:52 AM   #39 (permalink)
Default Pyro 700 6+6YY 1.32mm more compact
This is the version shown in post #31:
I just did the same wind again, but managed to get it more compact:
Old 01-05-2013, 06:31 AM   #40 (permalink)
Is this more for speed then torque? Would 500 kv be best for torque? Guess I'm saying what is different in 6+7 513 VS. 6+6 540.
kevinbj is offline        Reply With Quote Quick reply to this message
