Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
06-30-2015, 06:20 PM | #1 (permalink) |
Motor Pinion/Main Gear mesh
The Blade pinions are module 0.5, so I assume the main gear is also. Can a module 0.6 pinion be used the the main gear?
Thanks. |
07-01-2015, 05:34 AM | #2 (permalink) |
For gears to mesh their modules must be equal.
What are you trying to achieve?
Still Crashing, Still Learning 6HV-U, Logo550 & Protos all vbar |
07-02-2015, 01:37 PM | #3 (permalink) |
I'm thinking of doing a motor change. The pinions available for the motor are 0.6 mod. I suppose I could modify the stock Blade pinion. Is there a good source for aftermarket pinions?
07-02-2015, 10:10 PM | #4 (permalink) |
When I upgraded the motor in mine I drilled out a blade pinion. As I recall I wanted to go up a tooth and bought a 300x pinion. I made a jig from soft pine and used the drill press. The brass is very soft so you have to be careful.
George - Goblin700(iKon2), Trex550e(iKon), Oxy3(microiKon), Taranis |
