Old 03-08-2012, 07:22 AM   #1 (permalink)
Default 3GX V2.0 out NOW
Anyone try it yet?
http://www.align.com.tw/alignhtml/3g...gx_update.html
E Zurcher
Align TREX 450 Pro v2 FBL, Kyosho Caliber 50, Blade 400, Blade MSR, Blade MCX, Blade MCPx
Airtronics Stylus 2.4, Spektrum DX6i
E Zurcher is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 07:25 AM   #2 (permalink)
Default 3GX V2.0 out now!
3GX 2.0 out now!
E Zurcher
Old 03-08-2012, 07:30 AM   #3 (permalink)
so any info on performance change?? anyone tested it?
fuzion is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 07:43 AM   #4 (permalink)
It says a bunch of upgrades, and dramatic stability improvement to small helis... I'll download it once someone else does
michael88997 is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 08:28 AM   #5 (permalink)
many changes to set up, and more capabiities from the unit itself w/o pc interface.
koppterx is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 08:56 AM   #6 (permalink)
Didn't see that yet. Since I just got my v1.2 flying I think I'll be leaving mine for a while
Although the updates text seems to have some very good corrections!
Ahhh what the hell, I'll do it tonight and be a tester
Blade 450X & Blade mCPX BL
Spektrum AR7200BX
ProgressiveRC's "The Neutrino Ticket"
DesJardins is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 09:38 AM   #7 (permalink)
Its calling for 8 degrees cyclic pitch. I wonder if its ok to leave the collective at 12 to 13 like I have on all of my set ups. Im running Leon Luke's 450 settings on my 450 pro (1.2 version) and have been so so happy with it. This does have an attraction to me on the 450 because of the slight porpose effect in FFF.
I dunno Im gonna wait till other people try it first.
Maybe Leon can chime in about his experience with the update.
700N DFC 3GX OS91HZR
700E DFC IKON KDE XF700-505 CCHV160
600E PRO 3GX 450 PRO 3GX KDE BLING
RAPTOR 90 3D OS91HZ 1ST HELICOPTER
TTRAPTOR903D is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 09:45 AM   #8 (permalink)
Since it specifically says DIR set-up needs to be 8 degrees on cyclic's initial set up I'm guessing you don't want to skip that step. I don't see any reference to collective values
Spektrum AR7200BX
Old 03-08-2012, 10:22 AM   #9 (permalink)
I am flying Leon Lukes settings on the 600 pro and I am very happy with the way it flies. I am going to wait a bit before I update. Hopefully L Luke will test it out and post settings soon.
jlaspilot is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 10:22 AM   #10 (permalink)
just looked at the software and looks complicated. when you set the 8 deg do you adjust it using swash afr then set it. the increase the swash again to set the maximum travel.
ollie is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 10:33 AM   #11 (permalink)
Default 3gx v2.0
how do you set the 8 deg and maximum travel.
do i use swash afr
Old 03-08-2012, 11:13 AM   #12 (permalink)
I plan on downloading it tonight. Won't get to fly due to high winds forcast through the weekend here in Albuquerque.
E Zurcher
Old 03-08-2012, 11:28 AM   #13 (permalink)
Subscribed
DX8, T-Rex 450 FBL Vbar , T-Rex 550 FBL Vbar, Goblin 700 Vbar
gsxrjohnny is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 11:36 AM   #14 (permalink)
what's with the "sattelite receivers cannot be too close during power up - must be outside of 30 cm" statement? Thats a long way away! Wonder if that applies to full size receivers too.
diggyduo is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 11:49 AM   #15 (permalink)
Does "Roll rate adjustments should not be done in the transmitter" mean don't use D/R?
Old 03-08-2012, 11:57 AM   #16 (permalink)
Good question...
That's what I take from it which I'd like to know specifically why if the case
Spektrum AR7200BX
Old 03-08-2012, 12:49 PM   #17 (permalink)
it might be in reference to the transmitter location - when the trans is too close during start up the sats will not bind properly.
Old 03-08-2012, 01:28 PM   #18 (permalink)
Nice to see they're still working on improvement. Allthough i've been glad with how it flies from the beginning.
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6
-kenny- is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 03:17 PM   #19 (permalink)
Default New 3Gx Firmware Version 2.0
Hello Helicopter Pilots,
We have some exciting news about our 3Gx. We now have a new firmware update version 2.0 that simplifies the use of the 3Gx. Easy to understand interface that enable access to all functionality. First upon opening you will notice that there is know longer specific model types. Also you can see starting points at a glance and make adjustments as you feel needed. This updated firmware will provide enhancements that you can feel and see in flight.
First thing you’ll notice:
Hovering stability, pilots doing hovering type maneuvers will feel a more linear control response. You have the ability to disable the cyclic pitch function to enhance hovering stability.
You can achieve stable fast forward flights regardless of helicopter size, and smooth transitions between maneuvers.
Now with cyclic and collective dampening function, for more stable flight and reduced power consumption.
Improved pirouetting compensation and added adjustment instruction, further improving pirouetting axial point.
With the above enhancement we have expanded the range of the 3Gx. The new soon to be released GPS module for the 3Gx will expand its functionality. We think you’ll enjoy the flight performance, and the expandability.
Best Regards,
Jeff Fassbinder
Align
Align, Conquer Your Heart
AlignCorp is offline        Reply With Quote Quick reply to this message
Old 03-08-2012, 03:32 PM   #20 (permalink)
I just flew 3GX v2 in my 450. It's very different. I'm flying the default cyclic settings and the gain at 12oclock and it feels smooth but sluggish. A little strange to be honest.
Not so good on the tail. I had the tail much better with v1.2. I think they have taken away too many settings. I get piro stop bounce before I have enough gain. I might try more lock gain and see how that works. It also feels like there is quite a bit of fixed expo on the tail now.
Oh yeah, I think the reverse drift is sorted, if not, it's a lot better. The wind was a bit variable so it made it a bit hard to tell, but it definitely wasn't as bad as it was before upgrading to v2.
Early days yet, I suppose. At least it works.
Gaui X2 FES ZYX, Gaui X3 MB, Gaui X4 II VBar, Gaui X5 FES MB
250 DFC ZYX, 450 DFC Sport MB, ALZRC 450L Pro VBar, Devil 450 FAST VCTRC FBL
500E DFC Pro VBar, 500E SDC ZYX-S
KDS 550 VBar, 550E DHPS VBar, 550E DFC Pro VBar, 700E DFC HV iKon
beenflying is offline        Reply With Quote Quick reply to this message
