Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 600X
Blade 600X Blade 600X Helicopters Information and Help
Old 08-19-2016, 07:15 PM   #1 (permalink)
Default Is it worth repairing?
Crashed my 600x on Saturday, just shy of a hundred flights on it too, damage is around $250 with $85 of that in main blade cost, didn't pay to much more than that when I bought it used including battery, what would you guys do?
Current Align 700L v2 and 500x previous heli's align 600e, 450 pro, blade 600x, 230s, X3,-Blade nano, mcpx bl, 450 3d, mcp x v1 and v2, msr and mcx, 450x and beam v2
flyinggoose is offline        Reply With Quote Quick reply to this message
Old 08-19-2016, 07:30 PM   #2 (permalink)
Servos, motor, esc, fbl all still good I'm assuming.
if so I'd be looking to get a kit that meets the specs of the electronics and build it yourself.
Do you know why you crashed?
Écureuil AS355n.50 600mm - Lynx 450xl ntm1700kv 350mm- KDS Chase 360mm Scorpion 1880kv SK720be/Ikon
Waxxingibbous is offline        Reply With Quote Quick reply to this message
Old 08-19-2016, 08:19 PM   #3 (permalink)
Not sure what caused crash, was high enough to think and correct it, was inverted and giving it full negative pitch, but heli would not climb, I found the heli with elevator servo arm off servo and set screw gone, but I would think if that was cause for crash, heli would have flipped? Starting to think he may have been in an auto and didn't realize it, (motor shut down) looked at cc data log and don't see anything
Old 08-20-2016, 09:30 AM   #4 (permalink)
Fix it. That's a cheap crash for a large heli and you'd need new blades for another heli anyway. So, in reality, you're looking at well under $200 to fix it. It's a good flying heli and you're not going to get into anything else like it that cheaply. Unless you re-kit it, keep flying it until you can't get parts anymore.
Mike680 is offline        Reply With Quote Quick reply to this message
Old 08-20-2016, 09:58 AM   #5 (permalink)
Sorry to hear abut your crash, what parts are you needing, besides blades(all I have extra are 550)? I have several parts for the 600x.
I like this flying stuff.
Blade 180CFX, Blade 230S, Blade 600X, Trex 600E, Diabolo 700 LHS, Goblin 770C
jverhaeren is offline        Reply With Quote Quick reply to this message
Old 08-20-2016, 10:16 AM   #6 (permalink)
Parts damaged are bottom plate, landing gear, main gear, main shaft bearings, feather shaft and bearings, all links on head, boom and torque tube, main blades, not sure on main shaft. Got lucky, ground was soft from lots of rain.
Old 08-20-2016, 10:40 AM   #7 (permalink)
Sent you a PM
Old 08-20-2016, 01:38 PM   #8 (permalink)
I love mine , no matter what you have you will probably crash at sometime, you will never get a heli that flys like that, that cheap. I would fix it plenty of parts available
eightyduece is offline        Reply With Quote Quick reply to this message
Old 08-20-2016, 03:12 PM   #9 (permalink)
True, I just dislike the ones your not sure of what caused the crash, Il'll post the data log and see if someone sees something I'm not? The more I think about what happened the more I think I was flying motor less. Would main gear still strip if motor was off? Autorotation, I did notice just a few feet from impact it dropped faster while inverted giving it full negative pitch right at the end, was slowing down then dropped like a rock.
Old 08-20-2016, 08:22 PM   #10 (permalink)
Don't let the cheap entry put you off from fixing the 600 X. I had a crash of mine several months ago, a little more damage than yours (mine also needed a frame) and while large heli's take a bigger bite out of the wallet, there is nothing that can take the place of the adrenalin rush that one gets while tossing the 600 X around and hearing those big blades beat the air into submission.
wattflyer is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 08:10 PM   #11 (permalink)
I stripped a main gear once and managed to get it back down. They were designed a little on the weak side. If you stripped the main gear that might explain why you couldn't get collective. Mine was pretty noisy when it went through.
Protos Max V2 700 - Align 600E Pro DFC - VControl - VBar NEO - Scorpion Tribunus - Xpert Servos - Pulse Batteries.
reichly is offline        Reply With Quote Quick reply to this message
Old 08-22-2016, 02:56 PM   #12 (permalink)
Another thing to look at is the blade grip link (the link itself), the link that goes from the swash to the blade grip wear out quickly. Once propped off, no amount of collective will be able to slow the decent with just one blade that still has collected. Any looseness noted at all is asking for trouble on the 600X.
Old 08-30-2016, 07:13 PM   #13 (permalink)
Default Blade 600
I have a blade 600 without electronics for sale. Comes with many parts
Gregheli is offline        Reply With Quote Quick reply to this message
Old 08-30-2016, 07:20 PM   #14 (permalink)
Sent you a pm gregheli
Old 09-30-2016, 03:37 PM   #15 (permalink)
Parts finally ordered. Sure hope she flies like new again.
