Old 01-11-2011, 06:50 PM   #1 (permalink)
Default good servos for 3g trex 500
going flybarless on my trex 500. getting a 3g unit here on the forum. so now I will need servos. what are some good options.
heli list: 7HV ikon, Radikal g20 beastx
my videos http://www.youtube.com/user/nismo200sx16?feature=mhum
nismo200sx16 is offline        Reply With Quote Quick reply to this message
Old 01-11-2011, 07:35 PM   #2 (permalink)
Align DS510M.
Work perfectly in my 2 TREX500/3G
Jim Senicka
Team Captain, GrandRC Flight Team
Align TREX700N - TREX700E - TREX600LE - TREX500 - TREX450Pro
jsenicka is offline        Reply With Quote Quick reply to this message
Old 01-11-2011, 08:44 PM   #3 (permalink)
i would get align servo's for a 3G
Compass 7HVU HBL980/950 Ar7200bx Edge160-- Compass 6HV, 610/650
TRex 700LE , Beastx 610/650, Warp360 TracX 92A+
1BADAIR is offline        Reply With Quote Quick reply to this message
Old 01-11-2011, 08:55 PM   #4 (permalink)
The DS510's have been good with Vbar and Microbeast too, they worked better than Hitec.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 01-11-2011, 09:04 PM   #5 (permalink)
thanks guys. guess I am going to order some up.
Old 01-15-2011, 12:00 PM   #6 (permalink)
Align DS510M here as well running 6v
also if you have DS510 servos already you can just get the metal gear sets for them cheaper then all new servos
other then that run them at 6v to get full speed out of em
DX8
mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades
AMA#948801
Elios000 is offline        Reply With Quote Quick reply to this message
Old 01-15-2011, 03:09 PM   #7 (permalink)
I had hs81mg's on it so I got new ds510m's. good to know I can run 6v . thanks.
Old 01-15-2011, 08:19 PM   #8 (permalink)
your HS81MG's can run 6v as well and are as good as the Align servos and it looks like there metal gear as well imo keep what you have run it at 6v
:p you should of said what you had in the first place
HS81MG
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.11sec/60° at no load
Operating Speed (6.0V): 0.09sec/60° at no load
Stall Torque (4.8V): 36.10 oz/in. (2.6kg.cm)
Stall Torque (6.0V): 41.66 oz/in. (3kg.cm)
Operating Angle: 40 Deg. one side pulse traveling 400usec
360 Modifiable: No
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 8.8mA/idle and 220mA no load operating
Current Drain (6.0V): 9.1mA/idle and 280mA no load operating
Dead Band Width: 8usec
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Direct Drive
Bearing Type: None, outer case serves as bearing
Gear Type: 4 Metal and 1 Nylon
Connector Wire Length: 6.29" (160mm)
Dimensions: 1.17" x 0.47"x 1.16" (29.8 x 12 x 29.6mm)
Weight: 0.62oz (17g)
DS510M
Stall torque:3.7kg.cm(4.8V)
4.6kg.cm(6.0V)
Motion speed:0.13sec/60°(4.8V)
0.11sec/60°(6.0V)
Rating voltage: DC 4.8-6V
Temperature range:-20°C~+60°C
Dimension:35 x 15 x 29.2mm
Weight:29g
1520μs standard band
DX8
AMA#948801
Old 01-15-2011, 09:34 PM   #9 (permalink)
81's are analog.
Align requires digital servos. The refresh rate from the 3G to cyclic is too high to be safe for analog
Jim Senicka
Old 01-15-2011, 10:30 PM   #10 (permalink)
and they have no bearings.
