Old 01-12-2011, 07:47 PM   #1 (permalink)
Default How Do I Setup A Trex 700 3G Flybarless On A DX7
I have found nothing on how to setup this thing. I need pictures like a Dennys Menu to show me where to plug in the servos into the receiver and 3G unit. Please help and guide me to somewhere.
Many Thanks
The mysteries of hobby rationalization: Lesson 1
$5.25 for burger king combo meal: "rip off".
$399.99 for GY601: "worth every penny."
bladesmoker is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 07:49 PM   #2 (permalink)
I have found nothing on how to setup this thing. It came with no instructions. I need pictures like a Dennys Menu to show me where to plug in the servos into the receiver and 3G unit. Please help and guide me to somewhere.
Many Thanks
Old 01-12-2011, 07:58 PM   #3 (permalink)
Section 5
http://video.align.com.tw/mpeg/manua...G%20FBL-en.pdf
Kevin Williams
Team OFH
www.onlyfinehelis.com
Cyclone Blades, Scorpion Motors
eagleridge is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 08:11 PM   #4 (permalink)
Where does the yellow wire that says sen go to on the receiver? I have a AR7000 Receiver
Old 01-12-2011, 08:23 PM   #5 (permalink)
I believe that would go to the gear channel to control gyro gain for the tail.
Kevin Williams
Team OFH
Old 01-12-2011, 08:26 PM   #6 (permalink)
does this help?
T-Rex 450PRO V2, T-Rex 700E V2, T-Rex 500EFL Pro ICE100 Vertigo motor T-Rex 550 FBL BeastX, KDE/Neu, ICE100
superjoe83 is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 09:12 PM   #7 (permalink)
I thought the governor for the throttle went in the gear?
Old 01-12-2011, 09:16 PM   #8 (permalink)
I have this manual but it still doesn't show where to plug in the yellow SEN wire from the 3G & the orange wire. It shows nothing. But thanks anyway. Any other ideas? Surely someone knows?
Old 01-12-2011, 09:26 PM   #9 (permalink)
i know to use the Gyro gain and not endpoints you have to use the gear channel
not sure if your using a gov too but i would put the gov in AUX2
DX8
mSR, T-rex 500ESP 3G, Compass 6HV Savox servos Vbar 5.3Pro Rail Blades
AMA#948801
Elios000 is offline        Reply With Quote Quick reply to this message
Old 01-12-2011, 09:31 PM   #10 (permalink)
Yes, Gov to aux2
Kevin Williams
Team OFH
Old 01-12-2011, 09:49 PM   #11 (permalink)
Ok. I put the governor wire in aux 2 but where does the yellow wire go from the governor? Also, where do the yellow and orange wires go from the 3G unit? It should'nt be this hard. Right?
Old 01-12-2011, 09:55 PM   #12 (permalink)
ok should have 5 connecotrs coming out of the 3G unit
Aileron, Elevator, Pitch, Rudder, and Gain
Gain goes in Gear the others should be easy and then your gov have 2 leads coming out of it
one goes in the throttle the other with just one wire goes to AUX2
DX8
AMA#948801
Old 01-13-2011, 09:04 AM   #13 (permalink)
Smile The yellow wire
The yellow wire plugs into the gear channel of a Spektrum receiver. The transmitter must be set up to have the gear channel for the control of the rudder gyro so that 'mode' and 'sensitivity' (gain) are controlled through that channel. There is an explanation how to do this in the Spektrum DX7 manual. Spektrum uses this channel to set the mode to 'rate' if the value of the ATV is less than 50% and to 'heading hold' if the value is above 50%. The amount over or above the centre 50% value determines the gyro gain. two starting values could be say 35% for rate gain. and 65% for HH gain. A lower still % increases rate gain and a higher value gives more HH gain. You flick between the rate and HH mode by flicking the gear switch. Futaba is different where they have plus and minus values for gain. You might hear folk talking about that.
The orange wire plugs into the Rx pitch channel. Look at the plugs they all have the channels etched on them.
TRex450 PRO 3GX in Hughes 500E
Trex550E V2 3GX
TRex600ESP 3GX in Hughes 500E
TRex700E 3GX photo ship
SteamEngine is offline        Reply With Quote Quick reply to this message
Old 01-13-2011, 11:50 AM   #14 (permalink)
Thanks steamengine. That helps.
Old 01-13-2011, 09:08 PM   #15 (permalink)
Default Is There A Start To Finish Video Or Something On 3G Setup On A Trex 700 With A DX7?
I have tried everywhere and there is nothing on start to finish. I don't even know where to begin setting up my new 3G Flybarless. It came with no instructions. Where do I begin? Do I setup the radio or 3G? Where do all of the plugs go? I'm totally confused. Please help?
Old 01-13-2011, 09:10 PM   #16 (permalink)
Old 01-13-2011, 09:41 PM   #17 (permalink)
Check out this thread...hope it helps ya.
https://www.helifreak.com/showthread.php?t=194630
-you can't FIX stupid-
AMA# 935732
Altec is offline        Reply With Quote Quick reply to this message
Old 01-13-2011, 10:35 PM   #18 (permalink)
do you have the manual? that should help you with the plugs and stuff. I just used all the finless videos to build my chopper
this video was good once i was trying to setup my 3g controller
[ame]http://www.youtube.com/watch?v=XjnOpexd28g[/ame]
what kinda radio do you have?
Goblin Urukay Competition
Align T-Rex 700 Nitro FBL
DJI Mavic 2 Pro
ntwaddell is offline        Reply With Quote Quick reply to this message
Old 01-15-2011, 11:45 AM   #19 (permalink)
Surely someone on this site knows how to setup a 3G flybarless?
Old 01-15-2011, 11:47 AM   #20 (permalink)
Here's an entire forum section just for the 3G
https://www.helifreak.com/forumdisplay.php?f=222
Of all the things I've lost, I miss my savings account the most...
kevinb120 is offline        Reply With Quote Quick reply to this message
