Old 10-15-2010, 12:25 PM   #2141 (permalink)
Default trex 450sport sc noob happy hovering first vid
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/dwc4JIueixA...</param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/dwc4JIueixA?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Hi there,
this is my first hovering vid with my new trex 450 sport sc.
It's the 6th pack i ran and i'm loving it. This is also my first heli.
I think i'm hooked!
Hope it looks okay to you established pilots out there!
HuaHinEddy is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 09:00 PM   #2142 (permalink)
pix of mine
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote Quick reply to this message
Old 10-17-2010, 09:40 PM   #2143 (permalink)
carl,
how you like the g370?
mine will rip the boom off the heli if im not paying attention.
Crashs come easy Patience does`nt
retired the 3 year old blade400
fast400 is offline        Reply With Quote Quick reply to this message
Old 10-18-2010, 08:16 AM   #2144 (permalink)
It works great, yeah the responsiveness will stop the tail on a dime and give you change. I have to watch out for stripping the belt
That Heli now has a 3500G servo on the tail, way better than the 290G in the PIX, the 290 will probably make its way to the 250se later for a trial.
Carl
Old 10-19-2010, 04:02 PM   #2145 (permalink)
hey,mind your blades dont rip your gyro off mate!
Align 700L TOP Spartan Vortex VX1n
Align 550DFC V3 Spartan Vortex VX1n (the dogs nuts!)
Blade 180CFX
Futaba 8FG
JAG1 is offline        Reply With Quote Quick reply to this message
Old 10-19-2010, 05:14 PM   #2146 (permalink)
no worries, never had a strike at the gyro, if anything was near the support mount point and I don't usually have loose blades either. If I get something that close I have bigger worries like a rekit most likely.
Carl
Old 10-23-2010, 01:59 AM   #2147 (permalink)
fast400, your v2 looks nice. Well done !!
Did you had any issues fitting this sport canopy,
or you just drilled the mounting holes to the proper place?
Dimitris K is offline        Reply With Quote Quick reply to this message
Old 10-23-2010, 06:56 PM   #2148 (permalink)
the white tarot sport v3 canopy was pre-drilled, i just installed it. the fit was no problem.
the painted canopy was not pre-drilled, so i just put it on and marked where i thought the mounts would/should be. the painted canopy fits alittle loose, but not enough to cause any vib`s.
and thank you on you`r comment.
the first pic is the align v2 with the tarot sport v3 canopy, the second pic is the EXI v2 with the sport v3 painted canopy.
forgot to mention,
only thing left align on the align v2 is the frame, boom block and boom, the rest is all tarot.
i have the tarot cnc v3 pro and sport heads on all three heli`s.
i have the tarot touch bearing blocks in all three heli`s.
i have the tarot sport v3 tail on the EXI v2, the black king tail on the EXI Le, and the EXI cnc tail on the align v2. this tail although better than align, will be changed out for the tarot sport v3 tail soon.
anything and everything that needs to be quality is now tarot on all three helis.
ID:	186557   Click image for larger version
Old 11-06-2010, 05:56 PM   #2149 (permalink)
Originally Posted by Blacksport350 View Post
Here's my 450 Sport along side a Blade Tandem Rescue. I took these pics for an MCXT review and used the 450 for a size reference but as it made for some interesting 450 pics, I thought I would post them. The 450 is sitting on top of one of my favorite toys.
Where's the heli(s) ? All I see is an M series Beemer engine. Very Nice!
trexasaurus is offline        Reply With Quote Quick reply to this message
Old 11-07-2010, 04:15 PM   #2150 (permalink)
I've had this heli for almost a year and still haven't got it in the air. Work got in the way for a while, so I'm just now finishing the build. Just waiting on a few odds and ends from ReadyHeli and then for a DX8. I'm a little worried about ESD so I grounded the tail boom to the negative battery lead. I'm still considering grounding the tail gearbox, but it's going to take a little creativity considering all of the anodized pieces are nonconductive unless the finish is removed.
ID:	189060   Click image for larger version
ID:	189061   Click image for larger version
ID:	189063   Click image for larger version
ID:	189064   Click image for larger version
gravydrive is offline        Reply With Quote Quick reply to this message
Old 11-09-2010, 02:31 PM   #2151 (permalink)
looks good. just one thing, it might be a bit nose heavy with the ESC ( Jazz ??) under the battery tray. I have it on the side frame near the motor on the opposite side of the tail servo to get the balance right. It is much safer spot as well in case of a nose-into-the-ground crash....
good luck with flying..
mmarian is offline        Reply With Quote Quick reply to this message
Old 11-16-2010, 10:08 PM   #2152 (permalink)
Here is my 4S 450 stretch, doing her thing in the back yard!
[ame]http://www.youtube.com/watch?v=Ap0gSibvIWY[/ame]
snjbird is offline        Reply With Quote Quick reply to this message
Old 11-18-2010, 09:55 PM   #2153 (permalink)
Hi Gravydrive, what is that gounding bolt for on the tail boom below the tail servo ???
autosonline2002 is offline        Reply With Quote Quick reply to this message
Old 11-18-2010, 10:01 PM   #2154 (permalink)
Hi Snjbird, I'm no expert in 3D, just green, but able to do minor flips on the sim, just wonder how do U do ur stick to make the heli go back/forth in a fast action, not forward flight, I mean when the heli is almost standing up, nose pointing up... if U dont mind to share the info. Thanks !!!!!!!
Old 11-19-2010, 04:18 AM   #2155 (permalink)
The tic toc, it is kind of a mix of cyclic vs collective, your using the cyclic to set the angle and the collective to move it and stop it.
Old 11-19-2010, 05:22 AM   #2156 (permalink)
Member
Wow, that thing has some power on 4S! Nice tic-tocks and funnels.
Old 11-19-2010, 10:59 AM   #2157 (permalink)
Thanks Bob, I'm starting to get a hang of her, very different to the old V1 she used to be, and much slower than the Pro.
Old 11-20-2010, 02:46 AM   #2158 (permalink)
Testing new MKS servo DS95 (Cyclic) witt Align 450 PRo.
Norman_nitro is offline        Reply With Quote Quick reply to this message
Old 11-20-2010, 04:39 AM   #2159 (permalink)
<a href="http://s30.photobucket.com/albums/c346/GRJ1971/?action=view&amp;current=DSC01952.jpg" target="_blank"><img src="http://i30.photobucket.com/albums/c346/GRJ1971/DSC01952.jpg" border="0" alt="Photobucket"></a>
<a href="http://s30.photobucket.com/albums/c346/GRJ1971/?action=view&amp;current=DSC01964.jpg" target="_blank"><img src="http://i30.photobucket.com/albums/c346/GRJ1971/DSC01964.jpg" border="0" alt="Photobucket"></a>
<a href="http://s30.photobucket.com/albums/c346/GRJ1971/?action=view&amp;current=DSC01960.jpg" target="_blank"><img src="http://i30.photobucket.com/albums/c346/GRJ1971/DSC01960.jpg" border="0" alt="Photobucket"></a>
71vwyourdaddy is offline        Reply With Quote Quick reply to this message
Old 11-20-2010, 06:43 AM   #2160 (permalink)
Member
71vw,
Here are your pics:
