Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 07-10-2012, 06:27 PM   #21 (permalink)
Cool, well I put 5 flights on it today, So Jason did you order same unit i did or another one?
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 07-10-2012, 06:49 PM   #22 (permalink)
nice... i ordered the zyx-01 since i dont have a sattelite reciever ... but other than that they are the same.
gdawgs56 is offline        Reply With Quote Quick reply to this message
Old 07-10-2012, 06:54 PM   #23 (permalink)
Sweet, hope you like it as much as me, hope my first 4 post in this thread helps you out.
I am running the full rx but did order the cable in case ever want to try it only thing i am confused about is where would you plug the esc into if you used the remote rx. not the full.
Old 07-10-2012, 07:28 PM   #24 (permalink)
yeah ... those posts helped me a lot ... especially the vids. Sorry, i dont know about the remote reciever and esc.
Old 07-11-2012, 08:45 AM   #25 (permalink)
it shows you in the software if you pick the dsmx sat option for RX type
the pic on the left is for binding, pic on the right is after bound.
Synergy E7SE / Synergy E5s / Blade 180 CFX
IX12, DX6, Real flight 8, ACCURC
gixster is offline        Reply With Quote Quick reply to this message
Old 07-11-2012, 09:11 AM   #26 (permalink)
Thanks for the picture, But now I am more confused, there is No open ports on the ZYX, So it shows plugging into the RUDd and Ail channels.
Not big deal right now I most likely will never use just the remote style rx but just be nice to understand how it does work.
Old 07-11-2012, 09:43 AM   #27 (permalink)
If you use sat rx there is open spots remember all 3 spots now going to the standard rx would not be used for the rx any more
iam using the beastx now on my heli but i am about to set up the zyxs in one of my planes, will show a quick set up video before i put it in
Old 07-11-2012, 10:41 AM   #28 (permalink)
here is a real basic quick way to set up a Sat RX
obviously you can do it with everything still in the heli, was just easier to see when not installed, using loose parts instead
Old 07-11-2012, 11:35 AM   #29 (permalink)
Hey can you check your wiring on the first post?
You wrote:
its got from right side to left
3 wire plugs in
Ail plugs into your AIl on the rx
Rud plugs into the rudder on the rx
Channel 3 your left rear servo plugs into here
Channel 2 your right rear servo plugs into here
Channel 1 your from servo (elevator) plugs into here
Channel 4 your rudder plugs into here
I thought it is:
Channel 4--rudder servo
Channel 1--Pitch servo, on the right side of the bird. From the rear
Channel 2--Aileron servo, on the left side of the bird. From the rear
Channel 3--Elevator servo, front servo.
Ive had a couple tip overs and want to make sure ive got it right. I have it different from you. I took that from the wiring thread, but yours seems to work.
M3bluegsr is offline        Reply With Quote Quick reply to this message
Old 07-11-2012, 11:47 AM   #30 (permalink)
true didnt think about that
3 wire plugs in
I thought it is:
Sorry i marked it wrong ch3 is ur elevator and 1 & 2 are your left and right dont matter what one what i guess u can reverse if needed
Sent from my ZTE-Z990G using Tapatalk 2
Old 07-11-2012, 05:09 PM   #31 (permalink)
Can i keep my original servos with the zyx unit?
Simon
Blade 450
Blade SR
DX6i
Phoenix
HeliQuebec is offline        Reply With Quote Quick reply to this message
Old 07-11-2012, 05:28 PM   #32 (permalink)
Simon
Blade 450
Blade SR
DX6i
Phoenix
Sure lots say stock better since digital just people complain cause they strip if you crash otherwise they work fine
Old 07-11-2012, 06:50 PM   #33 (permalink)
Thank you for the info and great job in this thread!!!
Blade 450
Blade SR
DX6i
Phoenix
Old 07-11-2012, 06:58 PM   #34 (permalink)
No problem your welcome and thanks well ive gota strange issue now it seems the fbl unit is resetting/rebooting itself it did it during spool up anyone ever had that happen before?
Old 07-11-2012, 08:16 PM   #35 (permalink)
That has never happened to me. I've had my cx-3x1000 for 9+ months now.. Brown out of some type maybe, or a loose connection from the ESC to the FBL unit?
Current fleet is getting smaller.
Blackout Mini-H, WarpQuad 230, Blade 200qx, Nano QX, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX6 radio.
Previous fleet: mcpx, 300x, 350qx,450x, qav400, DX7s
InFocus is offline        Reply With Quote Quick reply to this message
Old 07-11-2012, 08:22 PM   #36 (permalink)
sorry, dont know about that . Hope you get it figured out
Old 07-11-2012, 08:48 PM   #37 (permalink)
My rx is not going into brownout just the fbl unit is rebooting.
Are you running stock ESC? any kinda external BEC
yeah me to Not sure what heck going on, going try few more things.
started thead about it in the fbl section with a video
https://www.helifreak.com/showthread...10#post4098110
Well after some more reserch it seems the BEC in the esc is going out or sending spikes to the unit or something, I plugged in another esc and it working fine on the bench.
So i just ordered a external BEC will install that and hope it fixes it.
i do not have another heli esc to go on it so once again I am down a few more days man this Sucks,.
Old 07-11-2012, 09:40 PM   #38 (permalink)
Stock ESC, no external BEC for me.
Old 07-11-2012, 10:11 PM   #39 (permalink)
Well If it was not for bad luck I wouldn't have any luck, This heli has been a nightmare, Guess I should change out the tail servo,esc, motor then I will have replaced everything on the stupid thing.
Old 07-12-2012, 07:33 AM   #40 (permalink)
I'd be willing to wager you have a not-so-tight-anymore capacitor solder connection
https://www.helifreak.com/showthread.php?t=422164
nbisme is offline        Reply With Quote Quick reply to this message
