Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 08-06-2015, 08:54 PM   #41 (permalink)
HF MR Support
Default Belt
I'm running a 572XL belt with my X5 boom....Are you going to run boom supports?
Dremel the shaft opening to clear the ret. ring?
What ESC? ( I run a 100a W/3a BEC)
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 08-06-2015, 09:45 PM   #42 (permalink)
Thanks for the info.
I thought i have a 572. Turns out i have 3 522's and 532 that came with a 550 tail assembly from china. I used to run this heli with 500mm blades so i guess i needed spare belts?
As far as the snap ring I'm looking at a different type of ring that will work.
I still have the CC 80 I originally used on this heli. Never had a problem with it but this motor and 516mm blades might be a different story. I have a YEP 120hv but its pretty large for this frame set. Haven't decided on a bec yet.
-TREX600NSP - TREX500ESP -TREX450FBL - TREX250 - CHP GAUI 550 - OXY3 - 30% EG Aircraft MX2 DLE55 -
JaggedEdge is offline        Reply With Quote Quick reply to this message
Old 08-06-2015, 10:08 PM   #43 (permalink)
HF MR Support
Default 516
I usually run the 500mm Gaui Wood blades ( had a few in my "Stock" ) also cause they are light too...when I want more "Floaty" 550 FG Pro 3D blades ( cant afford 550 CF blades) 80a will be fine !
Old 08-07-2015, 02:40 AM   #44 (permalink)
Nice to see someone resurrecting an old Hurri.
I still have 2 425's, a medium boomed one built on a HeadHunter frame, and my original plastic framed 550. Also have a new- in- box HeadHunter frame that has been sitting here for several years that never got built. Too bad Gaui discontinued parts support for the old Hurri's. I have found that many of the X4 and X5 parts can be used though.
I don't need the latest and greatest. I just need more time to fly what I have.
Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd
Jerrymac is offline        Reply With Quote Quick reply to this message
Old 09-21-2015, 08:16 AM   #45 (permalink)
Still working on this heli when I have a spare few minutes. Mostly wiring which is almost complete. Dealing with some setup problems with the V(K)Bar.
After spending an evening getting no where with the FBL unit I decided to take a week or so off and just think about it.
Old 09-21-2015, 10:59 AM   #46 (permalink)
I've got ^ of them (not on a Hurricane) if you want some help ...
Old 09-21-2015, 12:04 PM   #47 (permalink)
Sounds good Mike. I'll get some information together and hope you can help.
At this point I get the TX connected, swash and rudder move with tx input. Vbar software connects to V(K)Bar but does not show TX movement in software.
Old 09-21-2015, 03:04 PM   #48 (permalink)
Just work your way through the Set-up tabs in order and you'll be golden - it sounds like you probably haven't got the Receiver tab set properly.
Also check that you have your Transmitter set to 90 degrees / 1 servo / Normal / whichever it is on you Tx / Rx that gives you separate channels for ELE / AIL / PIT.
Mr Mel has done some absolutely excellent videos that will walk you through the set-up process
Old 09-21-2015, 03:06 PM   #49 (permalink)
Just so you guys know, there is still an observer of this thread and of tree'd hurricanes here. Lol. I still got my hurricane in the hughes 500E fuselage, but it needs to get flown.
Cheerio Gentry
PhillyD is offline        Reply With Quote Quick reply to this message
Old 09-21-2015, 09:38 PM   #50 (permalink)
Just flew my 550 tonite. Flipping and rolling it.
weav01 is offline        Reply With Quote Quick reply to this message
Old 11-19-2015, 01:25 PM   #51 (permalink)
Haven't done a thing to this heli since I started setting up the KJoyBar.
One of these days I'll get it done.. but probably wont be until spring.
