Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 06-09-2010, 11:18 AM   #1 (permalink)
Default Dampeners
I had the guy at my LHS tell me that the B400 and CP head dampeners are the same. I put in a set of the CP ones and they seem just as soft as the SR ones. Anyone know if the B400 ones are different form the CPs? I really do not want another boom strike now that I put on the carbon boom.
John
Blade mSR, shortened swash arms and flybar.
Blade SR w/ Detrum GY48V gyro, CF CP Blades, 10 T pinion, B400 head dampeners, Align 450 Landing skids, Axe CP canopy
SNOWFREAK is offline        Reply With Quote Quick reply to this message
Old 06-09-2010, 11:22 AM   #2 (permalink)
I've heard that the B400 do work, but I have no experience with whether or not they're stiffer. However, I do know that the trex 450 v1 o-rings fit and are much stiffer.
- 6S TREX 450 Pro FBL - µBeast, MKS, Castle Creations
- Goblin 500 - Kontronik Pyro 600-12, Jive 100lv, iKon, BK servos
- TBS Discovery - Pixhawk
- Spektrum DX7
SeanM is offline        Reply With Quote Quick reply to this message
Old 06-09-2010, 11:28 AM   #3 (permalink)
Yeah, I tried to get the Trex ones, but neither LHS near me carries them. Guess I'll just need to really work on those soft landings!!!!
John
Old 06-09-2010, 02:55 PM   #4 (permalink)
BCP and B400 o-rings are the same. You get 4 in a set, and it's labelled for the BCP. You also get some tubing which is useless for the B400 or BSR.
Align 450 V1 o-rings work great and I've reused them after many crashes. Getting them to seat just right with the spindle in place can be a pain, but its worth it.
BrandonB is offline        Reply With Quote Quick reply to this message
Old 06-09-2010, 04:57 PM   #5 (permalink)
trust the blade 400 orings are stiffer than the stock SRs orings. I changed mine out and its much better and stiffer
E-fanatic is offline        Reply With Quote Quick reply to this message
Old 06-09-2010, 05:04 PM   #6 (permalink)
You can also add a shim or two to each side as well.
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote Quick reply to this message
Old 06-10-2010, 08:25 PM   #7 (permalink)
5 shims per side and stock o-rings is a very stiff combo and mine set up that way lasted about 70 flights before I had to change out the o-rings
Blade mSR, UM T-28, Custom F-27C,SU-26xp, PZ Extra 300, 3DHS 48" Edge 540, Edge 540QQ, DX7S, DX6i
Any landing you can taxi back from is a good landing!
marcoeldragon is offline        Reply With Quote Quick reply to this message
Old 06-10-2010, 08:33 PM   #8 (permalink)
This ^
TL697 is offline        Reply With Quote Quick reply to this message
Old 06-10-2010, 08:44 PM   #9 (permalink)
You could cut some dampers from some nitro fuel tube,i used orange.
Stiffened it right up just be sure to cut them the same width and a nice square cut.
Heli Bones is offline        Reply With Quote Quick reply to this message
Old 06-11-2010, 01:07 AM   #10 (permalink)
My SR endured a tail boom strike yesterday on a very hard landing. This was with HK CP woodie blades, B400 o-rings and 4 shims!!! This was not a crash, I landed super hard in idle up. From now on I'm only using Align 450XL v1 model 1186T o-rings.
http://www.amainhobbies.com/product_...ing-3x65x2mm-4
These are stiffer than B400 o-rings.
Old 06-11-2010, 01:18 AM   #11 (permalink)
Originally Posted by BrandonB View Post
I landed super hard in idle up. .
Uhhh, you ain't supposed to do that bro.......LOL
Blade SR - Stretch Carbon Tail Boom
EXI 450 Carbon SE
Futaba T7C 2.4 FASST
Southern Heart Soaps Lotions & Potions
hueman09 is offline        Reply With Quote Quick reply to this message
Old 06-11-2010, 01:36 AM   #12 (permalink)
Lmao! No insult intended, just got a laugh when I read that. Like I can see Hueman's face when he said it.>>> <<<
And I laugh cuz I've done the exact same thing and someone told me the same thing Hueman said.
Danno
Blade 500x, Trex 500xt, just back after some time off. You don't ever really QUIT helis do you??
DKS_ONE is offline        Reply With Quote Quick reply to this message
Old 06-11-2010, 12:00 PM   #13 (permalink)
Hey SNOWFREAK, you can get some O-rings at your local Amy's Hardware (or any hardware store, home depo, Osh etc. The local Amy's here in Sac carries lots of O-rings and ones that are identical to the Trex 450 v1's so look around I'm sure you'll find some. If for some reason you can't find some, PM me and I will pick you up some and send them to you. Hope this helps.
Rookiepilot83 is offline        Reply With Quote Quick reply to this message
Old 06-11-2010, 12:06 PM   #14 (permalink)
I'm in the "I can say that cuz I've done it too Club", Looks like we got a few new members
EXI 450 Carbon SE
Old 06-11-2010, 12:33 PM   #15 (permalink)
Cool, Thanks. I'll check the hardware store near my house. The bummer is I was just there last night picking up plumbing parts!!!
John
Old 06-11-2010, 02:10 PM   #16 (permalink)
I want my SR to be built so that I CAN do that though. Is that too much to ask? By the way, boil your skids in water for 10 mins then let it cool down. It will make the skids more springy and less prone to breakage. I did finally break my boiled skids after many idle up fast forward pavement slides (I do this on purpose, it looks awesome) when I snagged the skid on the lip of a manhole cover. It snapped and flew somewhere far away otherwise I would have glued it back on (shoegoo!).
Old 06-11-2010, 03:06 PM   #17 (permalink)
Well, as far as I know, no heli is designed to be dropped to mother earth so rapidly. So if that's what you're looking to be able to do, I would suggest stocking up on blades, booms, tail motor mounts, skids etc cuz that'll be the result. Unless you wanna roll with training gear on all the time...
Danno
